Question about Sharp Microwave Ovens
Error 002 - Sharp Microwave Ovens
Posted by lightingup on
Kevin Getz
    Genius:
  • 1,032 Answers
I would contact Sharp directly. I'm not finding any results for a 002 error code.
Posted on May 27, 2012
Where is the fuse for ge spacemaker jvm1320wb-002...the unit is totally dead...nothing works
It is time to replace the microwave oven, if the fuse is open you more than likely have a more serious problem that will be costly, companies only go back a few years when it comes to supply parts
Jun 16, 2012 | GE Microwave Ovens
I need a manual for the Samsung Classic Collection Microwave Model MW6710 002 as soon as possible? Thank you.
I'm not so sure repair is not cost-effective, especially as I doubt the quality of newer units. Mine broke after 20 years, amazing for a small appliance.
But I agree re safety. If the problem is more than a broken microswitch be wary.
Jan 05, 2012 | Samsung Microwave Ovens
I have a GE Spacemaker model JVM140H 002. The night lights work, but the main lights do not work, I can hear the relay clicking and the night lights go out.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Dec 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Hotpoint RVM 225 BL 002 power reset. Internal breaker?
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
I would suspect the fuse or magnetron thermostat.
May 15, 2010 | GE Microwave Ovens
GE SpacemakerXL, model #JVM1330BW 002, does everything but run
it could be a defective thermal fuse,h.v. cap,h.v. diode or the magnetron tube are defective
Oct 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a J HP60G 002 GE Microwave (older)keeps
If it blows the line fuse instantly when you push start.... it is either a shorted HV capacitor or shorted monitor switch.... most likely.
Sep 13, 2009 | Microwave Ovens
The microwave doesn't have power
Sounds very much like the magnetron is at the end of its life , if everything else on the oven is working but you don't get that familiar hum as the magnetron kicks in and I am afraid they can cost as much as a new oven especially with the repair cost , time to go to the store and get a new one it will probably be cheaper ... Regards Vortash
May 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Jvm1350ww 002 Handle broken
The handle part number is WB15X335 and is available from a number of sources online. You can replace the handle alone, but you need to take the inside door panel off to get at the screws. It's been too long since I've worked on a GE to remember if you need any special tools (some ovens have security screws holding things together).
Apr 01, 2009 | GE JVM1350BW/WW/AW/SY Microwave Oven
Microwave Ovens Logo
63 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Michael Thomas
Michael Thomas
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
