The motor shaft sleeve and spindle will need to be replaced, once this jamming has happened it becomes ongoing if you do not replace those inexpensive parts. You need to wrap some webbing tightly around the spindle attach the other end to something very solid (like a fence post) and then accelerate the motor part rapidly away from the post. Hold onto the motor very firmly or it will land on the ground.The webbing tightens instantly when it runs out of slack and the spindle will come off. Then you need to remove the motor shaft sleeve in a similar manner, I drill a hole in the end and use a shackle and chain attached to the post for that one. I use the leg of my workshop bench, most folks will not have a solid heavy bench like mine. If that sounds too hard just take it to your local K/A service agent, they will have done it many times.
