Cars & Trucks Logo
A
Anonymous Posted on May 26, 2012
Mazda Bt50 cab leaks on drivers side
Water leaking into cab on drivers side
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 27, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3054
Points
0
I recently purchased a 2008 BT50 dual cab then 2 days later we had 500mm of rain and of course it leaked :( I had about 80mm of water on the drivers side floor and 30mm on the passenger side floor. I stripped the interior out of the car and started hosing the outside and watching where it was coming in. I took all the windscreen surrounds off and the cowl panel off below the screen there was no water coming in from that area. I had taken the gutter seals off but left the door seals on so the water was running down around the outside of the seals (with the door shut) and out at the bottom. From inside near the drivers side kick panel I could see water coming through seams in the metal work and when I took the door seal rubber off the body on the car I could see water was getting in at the top of the door seal rubber going down the front inside edge of the rubber and getting in through the seam where the rubber push's onto the body of the car (first problem). I took all the door seal rubbers off and run a bead of non corrosive silicon inside the cavity and pushed them back on. It seemed to have fixed the problem I dried the carpet and put it back together..Two weeks later we got another 325mm of rain and it leaked again :( not near as bad this time. Looking at the bottom of the door where the door trim meets the door I could see water coming from behind the trim and then into the car. I took the door trims off and could see water gets in when the window is up (all cars do) and is supposed to run out the drain holes in the bottom of the door but the water was dripping and splashing up to the back side of the door trim against the sheet of plastic that is supposed to seal against the door with the black mastic (it doesn't) and running straight into the car. I cut some plastic and siliconed them onto each opening on the inside of the door frame and then put the factory piece of plastic on as well (properley this time) as a backup.
So far so good.
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Jan 09, 2009
SOURCE: Water leak on driver's side - 2000 Mitsubishi Galant
I was a manager at a Mitsubishi dealership.
There was a "secret warranty" on certain Galants where the firewall seam would fair and leak water into the interior. Call your local dealer to see if your vin qualifies. The fix is to simply reseal the firewall crimp seam with silicone sealant.
Alternatively, sunroof equipped cars sometimes get the drain channels clogged in time. Make sure to clean drain holes and use forced air if necessary.
Lastly, some cars have heaters with pollen filters. If those filters become clogged, condensation can accumulate and overflow into the interior.
If any of these solves your issue, please rate my answer
Anonymous
  • 1861 Answers
  • Posted on Sep 08, 2008
SOURCE: there is a water leak
Your A/C drain hose may be plugged. If so, the condensate from the A/C box will leak onto the floor, and eventually soak the rear carpet as well. This is a common issue. It is under the glove box, close to the passenger floor. Remove it and make sure that it is open. Alos, always run the A/C in the RECIRC mode.
Water in the trunk can be from a bad trunk seal or poorly sealed taillamp seams
Anonymous
  • 3 Answers
  • Posted on Mar 16, 2009
SOURCE: My 2003 hummer H2 is leaking water into driver
had d same problem , check your rubber seal between door hinges and the body .
Anonymous
  • Posted on Sep 24, 2009
SOURCE: water on passenger floor...
water leaking into the passenger side (foot wells) of Mazda 3, 2007 model
Anonymous
  • Posted on Oct 25, 2009
SOURCE: Water Pump leakes from steel tube.
when installing new o-ring on tube, lubricate o-ring and stick it in water pump. Then pull pressure back on tube and then tighten hold down clamp. problem solved
2010 Mazda BT50 with 2.5 TD 4x4 double cab. I need torque specs for it please.
Question edited for clarity.
Question moved to model category.
The Tecnical Manual has torque specs. Press CTRL+F and type the word 'torque' and press Enter. There are 7 mentions including a table.
Training Manual - Mazda BT-50
mazdabg.com https://www.mazdabg.com > BT-50_en
The dual mass flywheel compensates torque fluctuations thus reducing rattle noises of the transmission gears. BT-50_05014. 1 Torsional-vibration damping spring.
146 pages
https://www.google.com/search?q=2010+Mazda+BT50+torque+specs
1helpful
Whistle from turbo.. 2007 mazda bt50 2.5 diesel turbo. . While accelerating I get this whistle noise in the cab. High pitched sort of. it sounds like its around the passenger side footwell.. if driving...
locate the waste-gate and see if you can cover it temporarily while driving. see if this changes it any. It could have a pin sized hole in the diaphragm. just a guess.
5helpful
Mazda Tribute. Water leak under driver's feet. Had similar leak on passenger's side and it was the air-conditioning. Could this be the same?
Generally, water on the passenger side is the A/C drain tube.
Driver side generally means widshield or sun roof seal leak.
Did you wash the Mazda or did it rain prior to puddling?
Before disassembling the windshield seal, test ... with a water hose (Remove floormat and place a towel on newspapers on the driver's side floor).
There is a "smoke" test" that can more accurately find the leak. See if you local AutoZone will rent one (maybe free) to you.
3answers
1991 Suburban has water leak on drivers side floor when it rains.
check out your door seals may need replacing. drive it thru a carwash to locate the spot.
Top Mazda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mazda Expert? Answer questions, earn points and help others
