Brush wheel not spinning
it can be belt or clutch failed. put the vac on its side and on the bottom there will be either two push clips or 2 screws remove them or push them and pull the bottom off. then when this is off you will see were the belt is for the spinning brush. if the belt is still on then the clutch has gone in the motor if the belt has gone take out the broken part and get a new belt, fitting new belt you need to remove the spinning brush it is either clipped in or slotted in , clipped is push the clips out to the side and lift the brush out, slotted it will just pull out. clean out the brush before putting back in also check the brushes bearing to make sure it moves easy as a failed bearing do to carpet string etc can burn the belt, any belt that has been burnt in this way should be removed and changed as it will damage the hover if still used after this part has been cleaned replace all parts and then turn on dont and it pluged in mains while you are doing this and dont use until it has all been fitted back..
