Tasco 1200 Zoom Microscope X50 X1200 With Projector Hood And Discovery Tools Logo
Posted on May 25, 2012
Broken mirror and light
The light mirror mechanism is broken from the contacts how can i fix it or get a replacement?
shakwan
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 24, 2014
shakwan
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
146
Points
2answers
2015 Kia Optima EX Side Mirror
you would need to open up the mirror in order to determine what might be broken or worn out within it. You might use a for-dummies ebook (free/ ad supported) from their website about being a car mechanic to discover the steps to taking apart the car side mirror.
Thank you.
How to replace side mirror[ mirror only],ford focus,driver side, 2013 model
If the mirror housing is in place, Have one cut to fit. Glue it in. If the housing is broken, replace all of it. You can't fix a broken side mirror. Tried to many times.
How do I remove and replace a mirror on the passenger side.
BMW 540i Side View Mirror Removal 525i 530i - YouTube
? 8:16
https://www.youtube.com/watch?v=Bmm9M28dqv4
Mar 10, 2014 - Uploaded by bimmermerchant
BMW 540i Side View Mirror Removal 525i 530i. bimmermerchant ..... A truck recently side swiped my ...
How to Repair and Replace a Broken Side Mirror Glass ...
? 2:31
https://www.youtube.com/watch?v=uUcpzHx2ZR0
Jan 6, 2013 - Uploaded by AutoandTruckMirrors
This How To video offers you easy step by step instructions on how to remove and replace a broken side ...
How To: Replace The Side Mirror on a Dodge Caravan ...
? 13:58
https://www.youtube.com/watch?v=ldjeQsnAJ9M
Jan 26, 2014 - Uploaded by Daniel Scheer
This video is a step by step instruction for the removal andreplacement of the side mirror on a 1996-2007 ...
VW Golf MK4 - how to remove/replace door wing mirror video
? 3:00
https://www.youtube.com/watch?v=saIEH-CxRkY
Aug 10, 2014 - Uploaded by DIY Mechanics
VW Golf MK4 - how to remove/replace door wing mirror video ... How To install Replace Side rear View ...
Dodge 3500 Diesel power mirrors work side to side but not up or down
Check for voltage on the vertical power output at the switch when operated. If no voltage, try lubricating the switch contacts. Still no voltage? Replace the switch.
If there is voltage, open the mirror assembly and check for voltage there. Is there voltage? Do you hear the motor sound when you operate the switch? If you hear a motor sound but the mirror does not move, it is a mechanical problem which can be easily fixed. If there is no motor sound despite the presence of voltage, the vertical axis motor has burned out or seized. Try lubricating the mechanism and, if still a no-go, replace the motor or the entire mirror assembly.
1helpful
2answers
Drivers side heated mirror turned amber
1999 blazer mirror problems. First I would replace the mirror. You can get an after market right side/left side, heated on eBay very cheap. that's where I get mine. They work fine. But you say the mechanic never fix your other problem in the first place. So I wouldn't no where to start. What is the other problem? Im just taking a guess here. But check your connections under your door pannel. Make sure no wires are bare or crushed. Make sure if any, fuses are not bad. Make sure your heat system that runs the heat to your mirror's is operating proper. You might have a short somewhere or maybe its just time to replace the mirror. To me when you see an amber color to your mirror it's the same as a light bulb blowing out or the mirror is getting to hot and shorted out. Good Luck.
1helpful
How to replace light bulb on side view mirror
It's not possible to replace bulb in the light it's one unit with neon bulb you have to replace compleat light for that not the jest a bulb. it's most common fault in this model most of lights not working because of wiring broken or short circuit inside the mirror housing for remove and install light housing it's need experience to do that otherwise can damaged some parts inside the mirror mechanism I would like to advice you see the experience technician for mercedes to do that. and ask him to check wiring inside the mechanism first.
Passenger side mirror with HD gas light. Mirror popped out. Everything is still in tack and working. Can it be put back in place without buying new one.
look at the back side there is a circle of little teeth if some of them are broken and or missing you need a new replacement mirror,not the whole mechanical partthat bolts to the door.if no teeth are broken or missing then press the mirror back in place with the palm of your hand.carefully it can crack.hope this helped.
Bronica sq-b, mirror lock up lever was broken
Hi, I have the same problem - my lever plastic become broken in 2 days after I'vet body from KEH. Seems that iron topof the lever can be screwed in counter clockwize direction and after new one lever installed it can be screwed back and fixed with rubber cap.
But question to you - where did you get the replacement?
You can contact me on [email protected] at any time.
Regards,
Kirill.
Replacing visor courtesy mirror glass
two solutions, One www.car-parts.com or go to glass shop and see if they can repair it.
Top Tasco Science & Laboratory Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Collins Mccoy
Collins Mccoy
Are you a Tasco Science and Laboratory Expert? Answer questions, earn points and help others
