Question about Mitsubishi CS-31205 TV
Where is a manual for a mitsubishi CS-31205 tv?
winserp
    Master:
  • 363 Answers
You can then look at the official website
OSRS Gold for Sale
Posted on Oct 15, 2016
ninjaMommy
    Problem Solver:
  • 10 Answers
The manual for Mitsubishi TV model CS-31205 can be found by clicking the link below (Although the link says "CS 31305" , other models such as CS-31205, CS- 31309, and CS-31304, will use this guide as well)
Download Mitsubishi CS 31305 Owner Manual
Available for download (and offline viewing) in PDF format with a very short registration, or bookmark in your browser, and utilize online.
Or click below to visit the very useful website (the library is large, yet easy to use).
ManualsLib Makes it easy to find manuals online
(*just read this 2 year old question today- hope the OP found resolution)
Posted on Sep 30, 2014
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: Mitsubishi CS-35805 TV
Sorry to be the one to inform you Sheri, but this set is known to have several bad capacitors in the sweep as well as the power supply. Unless you have an ESR type capacitor checker, your going to have to take it in for service, by a pro. Hope yopu did'nt pay to much for it. Good Luck
Posted on Jul 24, 2006
Bill Heronemus
  • 308 Answers
SOURCE: Won't stay on
The quick horizontal line through the center of the screen usually denotes a failure in the vertical output circuit, and that would keep the set from staying on. You would have to take it to a repair shop for repair.
Posted on Dec 09, 2006
Anonymous
  • 1284 Answers
SOURCE: Black box in the middle of the screen
To be exact it is in the TEXT mode within the Closed Caption menus.
Posted on Feb 18, 2007
Anonymous
SOURCE: Universal Code for Mitsubishi CS-26201TV
After searching the web for hours this is the one that worked for me , if you have the same remote i have it should work for you too.
Code # 10150
Posted on Dec 21, 2008
Anonymous
  • 9 Answers
SOURCE: i was just given a
your tv tuner is bad just take it out and resolder the tuner
Posted on Jan 11, 2009
Mitsubishi CS-31205 TV Never had a remote for this great TV, but, accidentally pushed a button on my Comcast Cable remote and the TV is now in "Mute" mode. Not the Comcast box 'Mute' . Have...
You are supposed to be able to switch the Comcast Remote to TV mode and switch Mute on that remote to change back to standard volume. If that doesn't work try volume up on the TV. Otherwise if neither of those work then check Remotes.com for a replacement TV Remote.
1helpful
I need the code for unlock my tv, please help me with that.
I think you mean the parental control lock. You can bypass this added feature, or disable it completely by following the instructions in the appendix (page 84) of the owners manual.
You can find the manual by clicking the link below
(the guide is correct for your model number- its a catchall for other similar models)
Hope that helps
2helpful
Where may I buyt a Mitsubishi CS-32105 TV Remote? I have lost my remote.
Online. Just type in Mitsubishi CS-32105 TV Remote on your browser and bingo, many sales locations will appear.
Keeps turning off
high volt or b volt going to high. reg circuit not working  normal to shut down need tech to repair.
2answers
The closed caption is turned on. I don't have the schematic in front of me, so, I will wing it. There may be a button on the remote that says CC, if so then use that button to turn it off, if not then go to the service menu and you may have to search a bit. Either way it's an easy fix and you can do it yourself. If you can't find it, then, reply and I will give better instructions when I get into my shop next week.
Won't stay on
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
