0427,0422,0421. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier. http://electrohelponline.blogspot.com/
Try this link too http://remotesearch.blogspot.com/
If you've connected the DVD to the TV via HDMI or SCART you shouldn't need to 'tune it in', just select the HDMI or SCART input. If your TV is also a Freeview device and you want to tune it to Freeview, where you have the aerial connected to the DVD recorder, you need to also connect the DVD recorder to the TV via an RF cable or aerial flylead so that the aerial signal passes through the DVD recorder. It's all in the instructions
I had this problem aswell! I tried everything but ended up phoneing the help line, when they asked for what frequancies they found out i was picking up different ones form two different stations. I took the ariel out of the back on the freeview box and run a scan for channels (of course it came up with none as the ariel is unpluged but it overwirites and clears the incorect frequencies). Then plug the areil back into the freeview box and run a scan for channels. After doing this i picked up the correct frequencines form the correct station and my recordings actually recorded! If you phone the help line (08444159159) they will tell you what frequencies you should be picking up. I hope this qorkes for you!
However, i see what your trying to accomplish - being able to record the freeview pictures you recieve form the Sony inbuilt tuner onto the recorder.. whilst being able to watch a different channel..?!
Well, you cant. If your Recorder has an inbuilt digital tuner then of course this would solve your issues, whereas if it is purely an analouge recorder and your in an area that has switched over then youll need some new hardware unfortunatly,.
Phone Sony on 0845 6000124 local rate number for more advise
Sorry to say no it wont not unless the Tv set manuel says it has a Duel Freeview feed , you have to get another freeview box for the recorder .
besides If you used the freview in the tv 1 , the tv would have to be on when you wanted to record ?. and 2 you couldnt watch another channel whilst recording another .. only 1 tuner ?. also you could only record the program you had on .at the time no timer facility .
People are still used to the Old system of VHs and the fact that all videos had tuners built in so you could watch and record .. It will come and indeed some more modern DVD recorder have freeview built in again sorry but thats the facts , and dont forget if you want the pay per view channels on free view your going to need a tuner with a pay card port ... Regards Vortash
First ensure that the TV input is set on the Freeview channels, just in case.
Then check the antenna, when Freeview does not get all channels, it is always the aerial (antenna).
Many areas in UK have still poor reception. If you use an internal antenna, go to Argos or Currys and buy an amplified antenna for freeview, that will improve the signal.
