SOURCE: Driver Problems with XP SP2
Without the model number, chipset info and socket type of the mother board, it's hard to help. But you can check HERE and see if that's what you're looking for.
Did *********** board come with a CD disc? If so, the drivers are on it.
The last idea is to run Windows Update, as it will sometimes let you download updated drivers.
Hope that helps!
Geno
SOURCE: intel 845 display driver for windows vista
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1065
HERE IS LINK FOR DOWNLOAD
SOURCE: i bought hp desktop a6610in.
Normally the best place to get drivers is from the manufacturer's website. However, HP does not support downgrading this model to XP and thus does not have drivers available on their website.
Read first:)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01274160&lc=en&dlc=en&cc=us&product=3801395&rule=5756&lang=en
You can try to get generic drivers from the original manufacturer of the motherboard chipset. The problem is in identifying the correct drivers for your model. According to the product specifications from HP, your motherboard should be a Foxconn MCP73M01H1. The HP designation for this board is Napa-GL8E. If that holds true, the following drivers should work for you:
nVidia Chipset:
http://www.nvidia.com/object/nforce_630i_610i_winxp_16.08.html
(in particular, verify that this chipset driver installs the SM Bus and Ethernet drivers for your system before continuing)
nVidia Graphics Driver:
http://www.nvidia.com/object/winxp_169.21_whql.html
Realtek HD Audio:
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PFid=24&Level=4&Conn=3&DownTypeID=3
Other drivers will depend on the extra hardware installed (modem, card reader, etc.). Also, as this board uses High Definition Audio you may have to install the Microsoft UAA definitions before the sound card in order to get the sound to work.
Best to save all downloads to a folder (C:drivers) before trying to install. Please comment on your results.
SOURCE: D845GLVA - vista Home Basic - Display drivers
sorry no vista support for this board u have to get an ext graphics card for vista support nvidia ,ati , all are good
pls see this ur self ur on board vga doesnt support vista
http://www.intel.com/support/motherboards/desktop/sb/cs-008326.htm
pls rate me fixya for this if u like
