Question about Dell Computers & Internet
My Dell Latitude D620 will randomly give off a beep sound when powered on
The beeps is sometimes annoying and it's super super loud. The beeps just pops up whenever it wants especially when powered on, then after like every 10-15 minutes it beeps loudly ocassionally. Please advice how can l fix this problem?????
Posted by Bacco Diranga on
  • Bacco Diranga
    Bacco Diranga May 27, 2012
    The beeping noise comes in-between Bios start-up and log on screen am using windows 7 Ultimate Edition. It's annoying me please help tried all the tips given but none of them works so far.
  • ComputerHelpers4Good May 27, 2012
    ok you can control windows sounds by following my instructions
  • 821 Answers
Those windows sounds are adjustable
start
control panel
sounds icon
look for windows sound settings find the one that says beep and disable it
Posted on May 25, 2012
2 Related Answers
Anonymous
  • 381 Answers
SOURCE: Aspire 5315: Loud, Long, High Pitch Beep During Start Up
you need to replace the memory..or try to make clean using a Paper Eraser for make a clean the memory..clean the all pin connectors..good luck
Posted on Jun 25, 2009
Anonymous
  • 164 Answers
SOURCE: dell latiidue D620 beep codes
Manual:
http://support.dell.com/support/edocs/systems/latd620/en/index.htm
Hope this helps!
Posted on Mar 11, 2010
Beeps 5 times when booting up on battery
If you go to this site: http://en.community.dell.com/support-forums/desktop/w/desktop/3624.beep-codes-and-psa-diagnostic-chart you will find the beep code chart about 1/3 of the way down. You mention 5 beeps, but is it 1-1-3 ... in other words do you get a beep then another beep and then a burst of 3, or do you get a different combination of beeps? This has an impact as these are troubleshooting beeps to help identify what is going wrong.
1helpful
2answers
D620 display issue
Maybe your problem was not the lcd screen. Before you replaced the lcd screen you should have tried an external monitor to see if it would work. That would help isolate the problem which might be the Video Card.
If I'm not mistaking, the D620 has the Nvidia Video Card that was a major manufacturing defect. In fact my daughter had one and I had to reflow the video card because it was bad.
Count the Beeps and notice the pattern of the beeps ( 1 Long or 1 Long followed by 2 Short). They tell the technician what is going on with the computer. I'm betting you have a Video Card Problem.
I have a Dell Latitude C610; after initial 'DELL' screen comes up, the laptop gives one 'beep' then black screen and nothing more- power's still there; can get into setup and boot...
This chart details the specifics of what each 'beep code' means. Usually the codes come in series of 2-3 beeps not just one.
http://www.nullamatix.com/dell-diagnostic-beep-code-troublshooting-chart/
You should also make sure the 'dummy' stuff is done, like remove any floppy disks or CDs from the drive if you have one, and remove any USB drives from the laptop as they may try to boot off of them and not be able to. If you've done that, then check the chart in the link for further information. Sadly a non booting, beeping computer isn't a good sign. If I can be of any more help, please let me know.
Hope this response helps you out.
Best of luck!
I strive for '4 Thumbs Up'! If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
2answers
Slow dell pleez help
if the comp is off just power up the comp and when you see the dell logo immediately press and hold the CTRL adn tap F11 five times. you will have the option to restore computer.
1helpful
Latitude D620 beeps when it connects to the internet
go into your Intel PROSet/Wireless Application Settings (issue a Control + P from within the application) window. The setting that I changed was to uncheck the 'Show Information Notifications' box. This seemed to work for me.
1helpful
Dell D620, freeze with continuing lound sound Beep
Try running a good registry cleaner like Glary Utilities or Advanced Widowsystems. That should help. Also try checking for driver updates on Dell site.
Computers & Internet Logo
Ekse
Mandeep  Singh
Mandeep Singh
Michael Thomas
Michael Thomas
