Question about Rheem Heating & Cooling
Rooftop model RKMA-A060CL10E service manual
Service manual
1 Related Answer
Anonymous
  • 25 Answers
SOURCE: We need the wiring diagram(s) and/or service manual
the diagram should be on the inside of the electrical panel of the unit printed on a sticker
Posted on Aug 11, 2009
Dometic service manual
Are you sure the compressor kicks in?
Jul 11, 2014 | Dometic Rooftop RV Air Conditioner
I am looking for the service manual for Model No. 620425.331 Product No. 70531884
There are no designated service manuals for Dometics unless obtained directly from a service center.
Here is a link though to obtain an installation/operation manual if this would help.
http://www.dometic.com/enus/Americas/USA/Customer-Support/Operation--Installation-Manuals/
Jul 25, 2011 | Dometic Rooftop RV Air Conditioner
I have a coleman rooftop unit and the compressor doesn't start. I am wondering if it could be the freeze snesor thermocouple? I am not sure how to check it? How do I check the compressor start...
Here's a link to service manuals but be advised, there are many potentially fatal items such as capacitors, even when power is off, that can give excessive shocks to anyone not experienced in this field. I strongly advise you to seek experienced help rather than attempting to test any of these circuit if you are not experienced.
http://www.rvcomfort.com/rvp/tech_info/manuals.php
Jun 12, 2011 | Dometic Rooftop RV Air Conditioner
Hello , this is Bobby and I have a Coleman Mach rooftop air conditioning unit Model # 8335B8964 when I turn on the unit ,it throws the circuit breaker . I have replaced the starting capacitor and the...
Here's a link to a service manual, with step by step tests to determine whats wrong. I'm thinking compressor shot, but this should confirm, and or help you determine for yourself. Be careful with those capacitors eh !! Read warning in service manual.
http://www.rvcomfort.com/pdf_documents/1976141_copy.pdf
Oct 19, 2010 | Coleman Mach 15 Air Conditioner
I need the wireing diagram for a coleman rv/ac model # 6759-727
If it is mechanical controls at ceiling, this link should be it. It's a service manual, but has what you need and more.
If that's not yours, try ( http://www.rvcomfort.com/rvp/rvp.php ) and go to technical information and search for yours.
Jul 06, 2010 | Dometic Rooftop RV Air Conditioner
ROOFTOP A/C FREEZING UP???? NO FITTINGS TO CHECK REFRIGERANT????? NOW WHAT?????
You can get a line tap valve that clamps around the refrigerant line and pierces it allowing you to connect a guage and read the pressure. This is supposed to be a temporary set up. You should have it replaced with a permanent service port. New filter/dryers come with a service port.
Jun 01, 2010 | Dometic Rooftop RV Air Conditioner
A/C starts, goes immediately to heat
Unfortunately, your rear unit is calling for heat. If you put the rear unit on heat pump mode, does it then cool?
moz-screenshot-2.jpgmoz-screenshot-3.jpgThe reversing valve is energized in the cool mode of these AC's. So there is no real way to bypass it. I would check the thermostat and the control board in the unit to make sure that the switches are set correctly.
In the service manual section of the dometic/Rooftop RV Air Conditioner section. I have posted service manuals for the Heat Pump and the Comfort Control.
Hope this helps,
Jeff
Rate me please.
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
105 people viewed this question
Top Rheem Heating & Cooling Experts
Lawrence Oravetz
ray gallant
Marat Brikov
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
