RCA 25110RE3 Phone Logo
Question about RCA 25110RE3 Phone
How to factory reset rca handset model h5401
Messed up register handset now I can't get it back to the "register" mode.
1 Related Answer
Anonymous
  • 567 Answers
SOURCE: Hi I need some belt
This component has been discontinued and is hard to find now.
I researched a bit and managed to locate it though.
The RCA Removable Belt Clip (SKU#PC009) can be purchased here.
Please visit:
http://www.matelectronics.com/acatalog/Mat_Electronics_RCA_Parts_Explosion_Sale____469.html
Search for Reference #52774.
You will be able to purchase it from there.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
Posted on Oct 22, 2010
5helpful
2answers
Need to reregister att tl86009 with new base
The secret decoder key sequence, provided by AT&T tech support, to factory reset this handset is:
(right softkey "-") * 3 3 1 7 3 4 # (left softkey "-")
The handset they should beep and go into registration mode.
Re-Register TL86009
The secret decoder key sequence, provided by AT&T tech support, to factory reset the TL86009 handset is:
Connecting to base
read the user manual as the handsets have to be registered by the base unit to be connected
the main base is the operational unit
the other bases are just cradles to hold the phone while it is being charged
2answers
E4 - Erros My uniden phone model TRU 9485 - 4WX after outage power, now on LCD screen appear E4 and it didn't respond to any button when i press. I read some help which they say press 3 button...
Hello
Connect the phone line and power UP the base unit. Place the handset on base to get charged. It must reset automatically when you place the handset on base to charge. If not; resetting both handset and base unit is necessary.
Resetting the Handset
You may need to reset your handset in the following instances:
You lose a handset and purchase a new one. When you try and register to your existing base you get registration
failure.
You are unable to register any handsets to the base.
You had a base which needed to be exchanged by the manufacturer. When you register your existing handsets
to the base, the handsets say #3 and #4, but you only have 2 handsets.
When you are instructed to by the one of the manufacturer's call center representatives.
To reset, do the following:
Press and hold [ ] and [#] for more than 5 seconds. Select DEREGISTER HS.
WHICH HANDSET? appears. Select the handset that you want to de-register, and press the OK soft key.
DEREGISTER HS appears. Select YES, and press the OK soft key.
ARE YOU SURE? appears. Select YES, and press the OK soft key. You will hear a confirmation tone. The
handset will clear its registration information from the base, and then delete its own base information.
MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER TO OWNER'S MANUAL. To
re-register the handset to the base (see page 25).
If the handset cannot contact the base, it will display OUT OF RANGE. Make sure the handset is in range of the
base and the base is connected to power.
Note: It is also possible to reset the handset back to its original factory settings. All changes including Caller ID information
will be erased. For more information on resetting the handset back to factory settings and when you need to
do this, see www.uniden.com or call our Customer Service Hotline. See back cover page for contact information.
Resetting the Handset without the Base
If your original base is not available for some reason (for example, it is lost or somehow incapacitated), you can still
reset the handset and use it with another base.
Move the cursor to select BASE UNAVAILABLE and then press the OK soft key.
BASE UNAVAILABLE appears.
Move the cursor to select YES, and then press the OK soft key. ARE YOU SURE?
appears.
Move the cursor to select YES, and then press the OK soft key. You will hear a confirmation tone. The handset
will delete its own base information without trying to contact the base. When the base information is deleted,
the handset displays MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER
TO OWNER'S MANUAL. Register the handset to the new base (see page 25). of its user manaul.
OK.
1helpful
2answers
I just bought Model D-1660-2. I cannot make the second handset work. I have charged the battery for more than 20 hours. I set all the Handset setup modes as instructed in the manual. Works for the main...
Welcome to FixYa.
Reset the units/set up by doing the following:
  • Turn OFF all the HANDSETS.
  • Remove the batteries of the HANDSETS.
  • Unplug the power source of the BASE.
  • Unplug the phone line of the BASE.
  • Let it stay that way for 30 mins.
  • Insert the battery again of the HANDSETS, make sure it is charged properly.
  • Plug back the power source of the BASE.
  • Plug back the phone line to the BASE.
  • Register any handset that is unregistered (refer to manual).
Keep me posted.
Jas247
23helpful
2answers
How do i turn off the silent mode on a uniden phone, ive held down the # sign and nothings happening
Silent Mode
You can silence the ringers on the base and all handsets for a specific period of time; the answering system answers any incoming calls without playing anything through the speaker.
With the phone in standby, press and hold # on any handset. The phone prompts you to select the number of hours (1 - 9 or Always On) that you want it to stay in silent mode.
To confirm, press # or just wait about 5 seconds. The phone turns on the answering system and displays Silent Mode On on each handset.After the selected number of hours, the phone automatically exits silent mode. To exit silent mode manually, press and hold # again.
If the phone is in silent mode and you turn off the answering system, the phone exits silent mode.
Multihandset Features To use the features in this section, you need at least 2 handsets.
Your base supports a total of 12 cordless handsets: the one that came with the base and up to 11 DCX160 accessory handsets.You must register accessory handsets to the base before using them. (Handsets that came packaged with the base are already registered.)Handsets that aren't registered display a Not Registered message. For registration instructions, see p. 18, or see the accessory handset manual.If a handset was ever registered to a base, you must reset it before it can register to a new base; see p. 18, or see the accessory handset manual.Conference Calling
When an outside call comes in, two handsets can join in a conference call with the outside caller.
To join a call that's already in progress, just press Talk/flash or SpeSpeSpeaker.To leave the conference call, hang up normally; the other handset remains connected to the call.
8helpful
Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
2answers
Registering handset to base
I reviewed the user guide for that model, and I only see that it is an answering machine. I may indeed be wrong, but is there a chance you have a different model unit? Regardless of the model, normally you have to put the base in registration mode simultaneously when the handset it put in registration mode like you were doing before. If you do not have the user guide you can join Beoworld.org for $27 a year and download it for "free". I am curious to know if you have a different model or if you can register cordless handsets to the 1200. Maybe you can post an update. Just learning this model myself. Good Luck
1helpful
3answers
Doesn't anyone have an answer or some help? Please!!!!
Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
Top RCA Lands Phones Experts
Marvin
Marvin
Tom Chichester
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
