Question about Fisher Paykel EcoSmart GWL15
Fisher and paykel gwl15 has a code 234?
Cant find any infoon this code
Posted by cdickerson20 on
Greg Stephen
  • Fisher Expert
  • 566 Answers
Fault code 234
234. (11101010) Lid Lock Open Circuit
Check Harness to Lid Lock and connections at the Motor Control Module and lid lock ends.
Primary Fault: Connector to the harness, either end could be at fault.
Action: Replace Harness.
Secondary Source: Lid Lock has failed to be activated.
Action:
Tertiary Source:
Action:
Replace Lid Lock.
Motor Control Module has not responded to the Lid Lock being activated.
Check the lid has a tang and is fitted correctly to activate the Lid Lock. If this is all in order, the Motor Control Module must be at fault and needs to be replaced.
Posted on Dec 15, 2013
5 Related Answers
Anonymous
SOURCE: Fisher and Paykel EcoSmart GWL15
tilt the machine to get to the bottom and there is an electric pump that you can remove with no tools, you twist if out. after that is removed you should see what has clogged your pump.. I spent 4 hours disassembling my entire machine , cleaning it, trying to find out what was wrong. And the fix could of just taken me 1 minute.. Next time... But at least I know how to take everything apart now, very easy and simple machine to work on.
Posted on Apr 21, 2009
Anonymous
  • 51 Answers
SOURCE: Fisher and Paykel EcoSmart GWL15 Machine won't
It sounds like you need to re programme the machine.
With the machine plugged into the wall and turned on and the headset turned off this is what you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Posted on Jun 14, 2009
Anonymous
  • 86 Answers
SOURCE: Fisher & Paykel GWL15 washer won't drain. A
Hi There,You could bail out as much water as possible,Then If you lean the machine back against the wall,(with machine unplugged) you could remove the bottom plate (if fitted) and you will see the pump with a fan attached,Try turning the fan back & forth it may loosen the obstruction and you could then pump the water out before removing the pump for a service,A the front of the pump you will see a small plastic locking clip that needs to be held out while you turn the pump anti-clockwise for removel.Note treat everthing to be live on this machine if plugged in.(unplug machine before attemting any procedure) Best Regards.
Posted on Aug 21, 2009
TheMobilian
Dan Webster
  • 8221 Answers
SOURCE: how do I access the pump on my fisher paykel gwl15
On the bottom of the tub is this pump as you can has a locking tab you release and twist the pump a hair and it comes right out. Get ready to get a bath. LOL407103f.png
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 24, 2010
Paul Bade
  • 1688 Answers
SOURCE: my fisher and paykel ecosmart gwl15 won't do a hot
There are several possible causes. To track down the problem, first shut off the water supply valve feeding the washing machine, then remove the hot water hose from the machine and direct it into a bucket. Turn on the water supply valve. Does water come out? Is it hot? If you only get cold water, then you need to insulate the pipe between the water heater and the supply valve so you get hot water faster (assuming the water heater is working!)
If you have a supply of hot water, then check the inlet screen where the hose connects to the washing machine. Perhaps it is clogged with lime or sediment. If it is clear, then you have a fault in the hot water solenoid valve or water temperature selector switch.
Posted on Dec 05, 2010
How to change the water inlet valve fisher Paykel gwl15
Cut the cable tie off from the thermistor.
So the thermistor sits in the grommet straight.
May 07, 2013 | Fisher and Paykel Washing Machines
Fisher paykel gwl15 won't power on
Did you pump make loud noises before the machine stopped.
if pump did, replace pump and get the fuse in the board replaced.
Oct 08, 2012 | Fisher Paykel EcoSmart GWL15
Fisher and paykel gwl15 wont completely drain
Also check the clear pressure tube for blockages,
Blow air down the pressure tube to remove any blockages
that would prevent water level from changing.
Jan 02, 2012 | Fisher Paykel EcoSmart GWL15
I have a fisher paykel ecosmart wash cycle but when
Tip the Washer and check the hoses.... my husband just found 2 pennies stuck in one of the hoses in my F&P GWL15
Sep 30, 2009 | Fisher Paykel EcoSmart GWL15
Fisher paykel gwl15 overfills and will not advance
Is it filling so it is flooding your floor? Could be that too many suds are in the pressure switch tube ( are you using "he" soap? ) or the pressure switch is not registering the water level. Note the lights illuminated when it beeps and call F/P.
Jul 03, 2009 | Fisher Paykel EcoSmart GWL15
Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Getting inside the Fisher-Paykel GWL15 washer
thats it , remove those 2 screws and the top will flip back, the new "clothes guard"( neck ring), will snap right into place, be sure to rehook the spring to hte left front susension rod!
Mar 25, 2008 | Fisher Paykel EcoSmart GWL15
Fisher & paykel LW035-K
is the bowl floating freely,when full of water you should be able to move it freely with no clothes in it.the clutch may be stuck.or it may be a motor fault.check wiring etc,but you will need a rotor posistion sensor tester to find out.sorry i cant be of more help
Mar 12, 2008 | Fisher Paykel EcoSmart GWL15
Fisher Paykel EcoSmart GWL15 Logo
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
