Hi, seems like you may have a faulty aux jack socket(if the socket is mounted onto the face) or you may have some dry joints on the socket, or even a cracked pc board around the aux socket connections. also try cleaning the face connection pins both on the unit and on the face. if you not technically minded, check out you jvc repair center. cheers!
SOURCE: Does not switch to Ext Input
You need to enable the "Line In" option on your stereo. Press "SEL" for a couple of seconds to enter to special menu, change the input from sirius to Line In. Check the manual on how to do this. Once Line in is selected you press CD/CD-CH and it should change to Line In, Line in is then displayed on the screen.
SOURCE: MY JVC CD CAR RADIO DETACHABLE FACE LIGHTS UP LIKE
If this unit worked in the past, and there have been no repairs done that would have disturbed the connections, then its quite possible that you accidentally engaged the mute feature.
Good luck...
SOURCE: JVC KD-G110 car music system is taking CD and not getting played am not able to function any ...?
Hi. your radio has 2 power wires. A red one and a yellow one (with most decks) It sounds like your radio is getting only constant power but no "key on" power. Check your radio with the key on you should have power on both the red and yellow wires. If you are missing power on one of the wires theres your problem. If you have power on both wires then there is something internally wrong with your radio...
SOURCE: car cd player not working - flashing numbers...?!
sir ,
ur jvc cd player doesnot have function of normal cd . to play so cotect ur nearest car repair to help u
thanks
SOURCE: had a new battery put in my car and now when I
push the volume knob button in and hold it down until the psm menu pops up. your display should read "DIMMER" press the track forward button repeatedly until you get to "EXT IN" and then use the volume knob to select it. then hold down that volume knob button again for 4 to 5 seconds and your done
