Question about Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN All-In-One InkJet Printer
Override empty ink tank on Canon PIXMA MX860 - Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN All-In-One InkJet Printer
Gary
    Novelist:
  • 124 Answers
The title of this topic is for the MX860. It has no "RESUME" button, so the advice submitted by cene765 does not work. But there is a solution.
The MX860 has two black ink cartridges--one small (like the colored ones) and one large. So, you will run out of colored ink way before you run out of black. I found that by selecting the "Gray scale" printing option, I could still print with color cartridges being very low. Even when the printer told me that the color cartridges were empty, I could still print by clicking the "OK" button. However, this does not last. Eventually, the printer will flag the color cartridges with an alarm. When that happens, the printer stops working, freezing at the alarm until you replace the cartridge.
However, you can still print. What you need to do is press and hold the STOP button for a few moments. The alarm will be released and then you let go of the button. Printing can resume. This happened to me where the alarm was triggered by the cyan cartridge, before I could even try to print. When I used the STOP button bypass, printing started but was then flagged by the magenta cartridge. I thought for sure that pressing STOP while in the middle of starting the print cycle would abort it, but thankfully it did not--the alarm was cleared and printing resumed.
Posted on Jul 24, 2012
  • 2 more comments
  • Gary
    Gary Nov 04, 2013
    FYI, you have to hold the STOP button for about 10-15 seconds. Just keep pressing until the alarm light goes off.
  • Marlin Lillich
    Marlin Lillich Dec 29, 2013
    Worked Great
  • Matthew Bauman
    Matthew Bauman Apr 20, 2014
    Thanks! Needed to print something quick and didn't feel like running to the store, of course the one I was out of I didn't have on hand.
  • miltonsn27 Mar 02, 2017
    Wow works like a charm! Just pressed stop and print queue printed.
SDNA
    New Friend:
Dave81dave, the mx860 fix works. w/ a 2 yr old cartridge too. yay. thx.
Posted on Sep 12, 2013
  • 1 more comment
  • SDNA Sep 12, 2013
    dave81dave, the mx860 fix works. w/ a 2 yr old cartridge too. yay. thx.
  • SDNA Sep 12, 2013
  • SDNA Sep 12, 2013
4 Related Answers
Anonymous
SOURCE: ive had the ink cartridges refilled on my canon
Yes you can override this empty error, when the printer is on, press and hold stop/reset for 5 seconds until the empty lights go out.
Posted on Jan 26, 2010
dave81dave
SOURCE: My Canon printer MX860 will get half low on ink
This just happened with my MX860. I pushed the "Stop" button on the far right of the control panel and held until it beeped. Appears to do some kind of a reset. After that, the U163 error was cleared and it printed again. Don't know how long it will go before that happens again but it is working for now. Hope this helps.
Posted on Apr 27, 2010
Anonymous
  • 787 Answers
SOURCE: Canon PIXMA iP3000 waste ink tank showing nealry full..
Follow this procedure:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Nov 04, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: canon pixma mp130 waste ink tank almost full how
Hi There
How To Reset Waste Ink Canon Pixma MP130
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings.
From what I gather, it’s both a time consuming and expensive proposition to take to Canon to fix.
And they won't tell people how to do it themselves.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free.
You have to be slightly mechanical to do this.
If you you've never used a screwdriver and are all thumbs, but give it a shot or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
1.You will include printer
2. Press button MENU, then SCAN, COPY and again SCAN - they entered
into the service regime
3. Select NVRAM ACCESS and further BY OK.
4. Select SET Abs- m level and advance value equal to zero
5. Select SET Abs- r level (if there is) and also you will establish into zero
6. You will turn off printer by button POWER.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
How do I reset or fix an Error B200 Code on a Canon PIXMA MX860 Printer?
Dear
Please try the following to see if we can resolve your issue:
1. Open the cover of the printer.
2. Remove all ink tanks from the printer.
3. Lift up the gray locking lever on the side of the ink tank holder.
4. Gently remove the print head from the carriage unit.
5. Place the print head back in and lock the lever down.
6. Place all of the ink tanks back in the printer.
7. Close the cover and turn the printer off.
8. Unplug the power from the printer. Leave the power unplugged for about 5-10 minutes.
9. Plug the power back in and turn the printer on.
Thanks
Jan 15, 2015 | Canon PIXMA MX860 All-In-One InkJet...
How can I override ink selection and use only color when black ink is out on m Canon printer MX860
HI there,
Your printer software does not provide this option. You should try to get a black ink cartridge ASAP so the printer head for that cartridge does not dry out. If it does, you'll end up having to replace the head and you really won't be happy with what that takes.
Regards,
Selk
Mar 27, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
I have PIXMA MX860, I recently replaced new cartridges.. but all time when I switched on printer , error u140 comes.. please help me out
The ink tank is not compatible with this machine. (The lamp on the ink tank is off.) You can try reseat the cartridge if that doesn't work, you need to replace it.
Here's instruction on how to replace an ink cartridge for MX860 http://support-au.canon.com.au/contents/AU/EN/8200407400.html
Dec 16, 2010 | Canon Pixma MP500 All-In-One InkJet...
I just purchased a Canon PIXMA MX860 (factory recertified) and need the serial number to register the product. One post on the internet suggested the serial number is under the scanner glass in small...
the serial number on the this model is located on a small white label, on the front rail just below the area where you install the ink tanks. Its says `serial number' on it.
Oct 18, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
My Canon printer MX860 will get half low on ink and freeze up with error U163 telling you to replace the ink cartridge. Is there a way to override this error so you can use the remaing ink?
Apr 26, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Canon MP560 ink level override
Just press and hold down the STOP button :) Works a treat :)
Dec 28, 2009 | Canon MP560 All-In-One InkJet Printer
Ive had the ink cartridges refilled on my canon pixma mp240 and i need to override the 'empty ink' warning. its not printing the correct colours and driving me nuts!
Nov 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Pixma ip3600 not changing to 2nd black ink tank
you cant swap it for printing you have to refill the empty one
Feb 01, 2009 | Canon PIXMA iP1600 Printer
Canon Pixma MP950 Ink Refill Error
replace the cartridge with a Canon as the chip has gone on the cartridge.
this is the only way around it with the mp950.
This is to stop them being refilled
May 22, 2008 | Canon Pixma MP950 All-In-One InkJet...
Refilling Ink in Canon Pixma MP830
Hello, I found this in a repair manual for the MP830. summery is to press and hold the stop/reset button for 5 or more seconds. I copied the info from the manual too. The remaining ink amount unknown. [1683] (Applicable ink tank icon) The remaining level of the following ink cannot be correctly detected. An ink tank which has once been empty is installed. Replace the applicable ink tank with a new one. Printing with a once-empty or refilled ink tank can damage the print head. If printing is continued without replacing the refilled ink tank, press the Stop/Reset button for 5 sec. or longer to record the use of a refilled ink tank. Note: After the above operation, the function to detect the remaining ink amount is disabled.
Jul 17, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN  All-In-One InkJet Printer Logo
18,025 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
