A B LED light denotes that the black ink cartridge is running low.
A C LED light denotes that the colour ink cartridge is running low.
If the alarm light is on (lightning bolt in a triangle) it should be accompanied by an error code.
Canon MP495 - Error Codes
If the printer displays an error message, the following information should help to diagnose the problem.
The led screen on the printer will flash a letter E and will then be followed by two numbers:
Error
Description
More Info
Error E02
The machine is out of paper or will not feed.
Error E03
Paper jam or output tray is closed.
More Info
Error E04
The Cartridge cannot be recognised.
More Info
Error E05
More Info
Error E07
Cartridge is not installed in the correct position.
More Info
Error E08
Ink absorber is almost full.
More Info
Error E13
The remaining ink level cannot be detected.
More Info
Error E14
More Info
Error E15
More Info
Error E16
The ink has run out.
More Info
Error P02
Carriage encoder error.
More Info
Error P03
Line feed error.
More Info
Error P07
The waste ink absorber is full.
More Info
Error P08
Print head fault.
More Info
Error P10
Print head fault.
More Info
Error 5100
Carriage Encoder error.
More Info
Error 5200
Print head fault.
More Info
Error 6000
Line feed error.
More Info
Error B200
Print head fault.
More Info
Error 5B00
