Whenever I switch on the powers to the LED TV. The Back panel circuits of the TV makes chirping noise similar to the one you hear when you stand under a High Voltage wire or near a transformer. Also when I try to touch the screws, USB, HDMI ports or the Video in/out ports, I can feel the AC current. This phenomenon has started all of a sudden. I suspected it to be an issue with the power sockets, so I tested it at other power sockets. The same issue. I have tried connecting other equipments to the same power sockets but they have no issues. The Electrician also checked the main power and confirmed that the sockets are properly grounded. The TV however works without any issue, but the LCD body emitting the current is freaking me out and making me apprehensive to use it in the first place. What do you think is the issue?
It is possible there is physical leakage from inside the set to the exposed metal on the set===a test from ground to the chassis should reveal this==we use a leakage tester for this which will measure even a tiny amount.
Testimonial: "Thanks, got a Sony Service Guy check the TV and he says it is a grounding problem as the TV comes with 2 pin plug and the electrical grounding in the house is not equal."
SOURCE: Tv makes clicking noise but won't turn on
Definitely a power supply problem.I had the same problem and changed the power supply, and TV works normally. Depending where you buy the unit, it shouls cost around $150/--, and it is very easy to replace.
SOURCE: Red power indicator light is blinking
The flashing light indicates a short circuit inside the power supply circuitry. This type of repair is not a DIY without a multimeter, desoldering iron and hand soldering skills. I repair these power supplies, if you need further info write to [email protected]
SOURCE: My Sony Bravia turns itself off Stand by red light blinks twice.
If you bought it brand new from a dealer, I would take it back or have them come out and look at it. Less than a month old, it is still under the 1 year MFG warranty or the very best a 30 day one.
SOURCE: my lcd tv makes a humming noise
My 37 inch vizio did the same thing. go to your menu screen on the tv and go sound. My tv has an option to turn speakers on/off. Once I turned my speakers off and the back on again everything worked great. hope I helped! if I did please let me know! youtube.com/xniax1
SOURCE: LCD TV, No Power, No Standby LED, Buzzing sound from Power supply
sounds like either way your power board is bad- do you intend on replacing a component? I would look for Puffy caps- you know- leaking from the top-
