Question about Samsung Audio Players & Recorders
I need to convert a .mov file so i can open it with Windows Media Player?
Posted by Santanal on
  • Lily
    Lily Jul 30, 2019
    You need download and install a video conveter to convert MOV files.Or you can try renaming the file.The guide may be useful to youhttps://www.leawo.org/tutorial/how-to-co...
Nanny
    Genius:
  • Samsung Master
  • 2,351 Answers
You can convert MOV to Windows Media Player with Leawo Video Converter.
Step 1: Import MOV Files into the Program
Click "Add Video" to import MOV files or file folder.
Step 2: Choose WMV as the output format
Open the drop-down box next to the big green "Convert" button and then click "Change" to enter the "Profile" panel and select WMV as output format.
Step 3: Set parameters for the video
On the same drop-down box next to the green "Convert" button, click "Edit" to enter the panel and set Video Parameters if needed.
Step 4: Set output directory
Back to the main interface, click the green "Convert" to pop up a sidebar and set a directory for containing output video files in the "Save to" box.
Step 6: Start to Convert MOV files
Start converting MOV video by clicking the "Convert" button at the bottom of pop-up sidebar.
Also you can try some other mov players such as 5KPlayer, RealPlayer, Leawo Blu-ray Player, etc.
Posted on Apr 15, 2019
JoniB
How about this mov to avi converter
I saw it was suggested in similar question
Posted on May 24, 2012
5 Related Answers
76guest
SOURCE: Sansa e260 video question...
You need to use the sansa media converter program that came with the sansa on the CD. This is used for photos and for video. The supported files are listed on the screen once you open it.
Posted on Jan 08, 2008
Anonymous
SOURCE: how do i format my gogear 6045 device?
well, if you dont mind losing your data :( you can reset the device, simply use a pin, poking through the hole on the bottom of the player labelled reset
Posted on Dec 02, 2007
Anonymous
SOURCE: Sansa Media Converter will not convert MP3
Duh!
I went back and re-read the manual (phamplet) I downloaded the MP3 files directly into the e200. Works great now.
Like I said. DUH
Posted on Mar 10, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: Media Converter says "Quicktime not installed"
Restart your computer and retry
Posted on May 26, 2008
YourZEN
YourZEN
  • 820 Answers
SOURCE: NEED TO USE THE PHILIPS MEDIA CONVERTER
All support for the SA6045/02 is on this page:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA6045/02&slg=en&scy=GB
Scroll down to Software and drivers to see the Media Converter software.
Click the zip file and best would be to save the file to a location on your computer.
After the download finished, unzip the file with WinZip or Winrar.
Open the folders of the extracted files:
under folder
MC_2.0.2.80_SA33xx_SA61xx_Intl_GM_CD02004_0928 start Setup.exe to install Media Converter Software, ArcSoft.
MediaConverter for Philips converts following formats to player, into WMV :
AVI (Microsoft video I format), MPEG-1, 2, 4, DVD (*.vob), MOV, WMV, RM etc.
Needs Quicktime (for MOV) and Windows Media Player 11 (for WMV)
installations.
SA6045/02 manual:
http://download.p4c.philips.com/files/s/sa6045_02/sa6045_02_dfu_eng.pdf
Posted on Jul 24, 2010
Vvf file player
The following free software from Q-see Surveillance Systems will let you playback VVF files.
https://www.q-see.com/files/software/QSD004-32824_VX4SL.zip
Kind Regards,
Mark
Mar 11, 2014 | Dell Computers & Internet
Tip
Best way about playing and converting MPG/MPEG files on Mac
To play an MPG file, a QuickTime player on Mac couldn’t fully satisfied. If you have an MPG file and you want to play it on your Mac, you need to download some components for Mac players or some other media players. If you want to edit this MPG file in iMovie, you need to convert this MPG file into MOV format first, and then edit it.
If you only want to play your MPG file, here we recommend two components for QuickTime Player. The most popular components for Mac players on market are Perian and Flip4Mac. The first solution is download one from either official website.
Perianis an open source plug-in which enables QuickTime to play several popular video formats not supported natively by QuickTime on Mac OS X, i.e. AVI, DIVX, FLV, MKV, GVI, VP6, and VFW. If your MOV file is still on strike, try to uninstall your old QuickTime Version and download the latest one QuickTime 7.6.
Flip4Mac is for watching Windows Media files (.wma and .wmv) directly in QuickTime Player and viewing Windows Media content on the Internet using a Web browser. It’s not suitable for playing a MOV file.
How to edit and convert MPG/MPEG files to MOV?
If you want to do more and you want to edit it on iMovie or upload onto YouTube, you need a media converter for Mac to convert MPG/MPEG files to MOV formats. Mac MPG to MOV Converter will show you how to achieve it within several easy steps.
Download and install MPG/MPEG to MOV Converter for Mac here.
Step 1: After this Mac MPG/MPEG Converter is running , just click “ADD” button on the top, and choose your MPG or MPEG file you want to convert. If you have several MPG files and you want to put them together and get a complete MOV file, just check all the files and check the box in front of Merge into one.
Step 2: Click the “format” button on the thumbnail, select “Common Video” and Choose ‘MOV-QuickTime (*.mov)’ from the dropdown list . If you have no idea what kind of formats that your device supports, just choose according to the device’s name.
Step 3: Before pressing Convert button, we advise you check the setting first. You can change the settings manually, also you can use the original settings, which will work just perfect.
Step 4: If you have no use for editing MPG/MPEG videos, just press “Start” and begin to convert MPG video to MOV for your Mac.
Tips:
What is MOV?
MOV is a file extension used by the QuickTime-wrapped files. The format was created by Apple Computer to work with multimedia files. MOV is a container format and can contain video, animation, graphics, 3D and virtual reality (VR) content or text (for subtitles, for example).
on Jun 30, 2010 | Computers & Internet
Which video format is most preferred for QuickTime? can i convert wmv to mov format?
MOV is a commonly used format.I think MOV/MP4 format is suitable for QuickTime,WMV means windows media video which is most preferred for windows apps.QuickTime apps provide by apple,some apple apps are not supported other OS apps format file.so i think MOV/MP4 format is a best for QuickTime. http://www.aimersoft.com/convert-mov/convert-quicktime-mov-to-mp4.html
Apr 20, 2013 | Apple Audio Players & Recorders
Cannot play MOV video and the problem was MOV Codec mot installed to the laptop
The first solution is download Quicktime in Apple official website. And the second one is just get this video converter to convert your video to MP4 or WMV format and play with Windows Media Player.
Mar 01, 2011 | Compaq Presario Notebook
NEED TO USE THE PHILIPS MEDIA CONVERTER APPLICATION PROVIDED TO CONVERT FILES TO FORMAT THAT THE PLAYER CAN READ
under folder
installations.
SA6045/02 manual:
Jul 24, 2010 | Philips GOGEAR SA6045 MP3 Player
Can't copy old dogs, up in the air or surrogates. are there any software programs that let you try before you buy.
I use DVDFabGold, great software.
There is also DVDFabPlatinium which has more fearures.
Yes you can try before you buy. Go to this link :-
www.dvdfab.com/
Mar 21, 2010 | 321studios DVD X Copy Gold (200095) for PC
Converting .avi .m4v and .mov files to .wmv
WMV Converter is a powerful Video to WMV Converterwhich provides a very easy way to convert all popular video files to WMV video for playback on WMV multimedia devices such as Xbox 360, Zune, Zune2, Pocket PC, PSP, PS3, etc.
Jun 23, 2009 | Coby MP-C7097 MP3 Player
What DVD video formats are supported by BBK? I need to copy video files from my PC to show on TV. PC shows these videos in Windows Media Player. The videos were taken by Cannon camera in "MOV" file format.
Supported Video formats:
VCD,SVCD,AVI
DIVX,JPG
As you see no support for mov files
You'll have to convert these mov files to avi...
Go to http://www.radgametools.com/bnkdown.htm and
download the Rad Videotools.This little program helps you convert
all your mov files to avi. Burn the avi files on a cd and you should be able to play them on your dvdplayer..
Jay
May 20, 2009 | BBK Electronics DV965 DVD Player
VIDEO FILES OF CANON SX10 IS NOT PLAYING IN WMP
H264 is a "mov." file. Windows media player11 and Power DVD 9 do not support this type of file. If you don't like QuickTime, there are many free media players that will support it (VLC is a good one). You could convert the mov. file to an avi. file with a video converter program. Then your avi. format movie will play in WMP
Apr 10, 2009 | Canon PowerShot SX10 IS Digital Camera
122 people viewed this question
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
