Question about Locks & Locksmithing
Olympia Luggage Combination Lock is locked. How to open?
Chris Walker
    Top Expert:
  • Locks & Lock... Master
  • 1,551 Answers
Posted on Mar 29, 2019
4 Related Answers
Richie_asg1
Richard Perkins
  • 1036 Answers
SOURCE: Master Lock luggage lock
This PDF document explains it carefully -
http://www.masterlock.com/faq/pdf/620_630_646_647_Instruction_Sheet.pdf
Hope this helps.
Posted on Jun 12, 2008
Richie_asg1
Richard Perkins
  • 1036 Answers
SOURCE: Master lock 5400D lock box
Master lock offer a free replacement service for locks which develop a mechanical defect during normal use.
See their website here for further information -
http://www.masterlock.com/customerservice/
If the lock has been forced or tampered with to cause this problem, then a replacement is needed.
Hope this helps
Anonymous
SOURCE: I lost the instructions to reset the combination for two luggage
I lost the combination lock
Posted on Jul 12, 2009
Anonymous
SOURCE: reset lock on samsonite oyser luggage
i hope you can help me!
i went to change the combination on my locked Samsonite bag and when i closed it it would not open on that number.
i have tried the past number as well as the new one and it still doesn't open. thank you if you can help please it would be appriciated.
Carolyn
Posted on Jun 21, 2010
How to set a combination on a Samsonite 3 dial combo lock
How to set a 3-dial luggage lock - YouTube
? 1:22
https://www.youtube.com/watch?v=TI4AgFhcnys
Sep 16, 2017 - Uploaded by Distant Lands Travel Store
http://www.distantlands.com How to set luggage locks. Simple and easy instructions on setting luggage locks.
3-Dial TSA Lock® & Cable - YouTube
? 1:21
https://www.youtube.com/watch?v=QlysHXuaftY
Jun 28, 2012 - Uploaded by Eagle Creek
it comes with a 50 inch cable. so that you can use this combination to go ahead. and secure different pieces of ...
How to Reset a Samsonite 3-Digit, Built-in Combination Lock ' USA ...
traveltips.usatoday.com > ... > Vacation Excursions > Things to Do on Vacation When purchased, the locks are set on a factory default combination that you can change as often as you wish. Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage. Locate the reset button, usually placed to the side of the combination dials. People also ask How do I reset my Samsonite luggage lock?
How do you open a combination lock without the combination?
How do I set the lock on my Samsonite suitcase?
How do you change the combination on a TSA lock?
Feedback
Lock Instructions - Samsonite
https://www.samsonite.ca/lock-instructions.html Luggage locks approved by the TSA have a universal master key that will open the locks (the keyhole you will see on your TSA lock, when you have not been provided a key ... Every TSA approved lock has an identifying mark that shows it may be opened by the master key. ... Have the lock set on your original combination.
Mar 17, 2018 | Samsonite Photography
How to Reset t tsa lock on a Mia toro luggage
How do I set a Mia Toro luggage lock? - Fixya
www.fixya.com/support/t26581106-set_mia_toro_luggage_lock
Apr 30, 2017 - Release the reset button after you set the numbers to the new combination. ... If you still can't open the lock, contact Samsonite Customer Service at .... TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to ...
Amazon.com: Questions And Answers: How do you set the luggage ...
https://www.amazon.com/forum/-/Tx1WRFLRQIYMJR0/ref=ask_ql_ql_al_hza?asin... Jun 20, 2016 - Mia Toro Metallo Composite Hardside 26 Inch Spinner, Blue, One Size ... The factory setting is 000 make sure lock is set to this press the reset ...
How to Set A Luggage Lock / LuggageFactory.com - The Travel ...
https://www.luggagefactory.com > ... > How to Set A Luggage Lock Sep 10, 2014 - TUMI: TSA Combination Padlock: Make sure the combination is set back to (0-0-0), the factory setting if new, or the existing combination if it has been used already. Make sure the mechanism is unlocked. Press and hold the button on the side of the lock. Select a new combination.
how to Reset tsa lock on Mia toro luggage Google Search
Jul 26, 2017 | Locks & Locksmithing
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
STEP 2
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
Aug 28, 2016 | Luggage & Travel
TSA opened our lock on our Delsey luggage, I now am unable to lock the suitcase. How can you reset the lock on the Delsey luggage after unlocked by TSA?
1. Look for a small recessed button below (on the bottom side) the TSA key access.
2. Push in the button with a paper clip or pen.
3. While the button is pushed, change the combination to the desired numbers.
4. Then release the button and the combination has been reset.
I also found this, but it needs to be open/
http://www.ehow.com/how_6927475_reset-tsa-lock.html
Dec 08, 2015 | Delsey Helium Shadow - 25 Trolley Luggage...
How do I can unlock dial lock
The master dial lock is the world's best selling combination padlock.The lock uses three digit combination of 40 numbers.allowing for 15,00 possible variations
.Follow these step to unlock dial lock. 25284217-gdc3ufgmlwaqnv2deqjxyac2-5-0.jpg With the Combination Step 1 Turn the lock until the numbers read right-side-up. Roll the left-most dial until the first number of your combination lines up with the scored hash mark just to the left of the dial.
With the Combination Step 2 Roll the middle dial until the appropriate number lines up with the number to its left. Do the same for the right-most number. Your three-digit combination should now show, left to right, lined up with the scored hash marks.
With the Combination Step 3 Pull the body of the lock away from the U-shaped metal ring without turning any of the dials. The lock will click open to expose a hook. The hook spins 360 degrees so that it can be placed onto, and taken off, luggage.
Forgotten Combination Step 1 Pull the body of the lock and the U-shaped ring away from each other to put pressure on the mechanism inside the lock. Pull the body of the lock away from its attachment, or, if the lock is not attached, apply pressure on the U-shaped ring away from the body of the lock with your fingers. Keep holding a firm, steady pressure.
Forgotten Combination Step 2 Roll the dial closest to the U-shaped ring slowly, while keeping steady pressure on the mechanism. The dial will get difficult to roll over three consecutive numbers, and one of those numbers will click. You should feel and hear this small click, and that is the first number to your combination.
Forgotten Combination Step 3 Repeat Step 2 with the middle dial, and then the farthest dial. Leave the dial set when you find the click, moving onto the next dial. The combination will reveal itself, letting you pull the U-ring away from the body of the lock.
Resetting Your Combination Step 1 Hold the body of the lock so that the numbers face away from you. Set the combination and release the U-shaped ring.
Resetting Your Combination Step 2 Turn the hook of the U-shaped ring counterclockwise 90 degrees until the notch on the stem of the hook and the hole on the body of the lock line up. Push the stem of the hook down into the body of the lock as far as it will go.
Resetting Your Combination Step 3 Turn the hook another 90 degrees counterclockwise while it is depressed into the body of the lock.
Resetting Your Combination Step 4 Roll the dials until you have your new combination.
Resetting Your Combination Step 5 Turn the hook 90 degrees clockwise and raise the stem out of the body of the lock. Turn it another 90 degrees clockwise and push it back into the locked position. The lock now uses your new combination.
Sponsored Links
Luggage Trolleys Supplier
Supplies Made to Order from World's Largest Supplier Base. Top Deals!
www.alibaba.com $0.01 Web Hosting
Scalable, Secure Web Hosting. Try Our Award-Winning Service Now!
www.hostgator.com/1Penny Rooftop Air Conditioner
low noise, high static pressure. Made in China, Inquire Now!
www.airconditionings.cn Download Facebook Apps
Get The Most Popular Apps For The Largest Social Network. Join Now!
www.facebook.com by Taboola
Sponsored Links
Move Over, Turkey: 9 Side Dishes that Will Steal the ShowKraft Recipes See Another Side of Dubai in HattaDepartment of Dubai Tourism & Commerce Marketing by AFAR
Email Best Practices: Sending Emails That Won't Be IgnoredRackspace
TIP
  • Email yourself the password to your lock, and title the email "Luggage Lock." If you forget the password in the future, simply search your email for the term "Luggage Lock."
WARNING
  • Do not open a lock that does not belong to you. It is against the law.
REFERENCES
RESOURCES
ABOUT THE AUTHOR Christopher Michael began writing in 2004 for his college newspaper. He received a Bachelor of Arts in English and psychology, as well as a certificate in criminal justice from the University of Massachusetts, Amherst.
PHOTO CREDITS
  • Creatas/Creatas/Getty images
Suggest an Article Correction
How to Open a Combination Lock on a Samsonite Suitcase
  • How to Reset the Combination on an American Tourister
  • Airline Rules on Locked Luggage
  • How to Reset a TSA Lock
  • Reagan Airport & Luggage Storage
  • How to Prevent Lost Luggage
  • Cost of Shipping Luggage Ahead to Destination
  • How to Repair Wheels on Luggage
  • The Odds of Losing Luggage
  • How to Make Inexpensive Luggage Tags
  • Solutions to Lost Luggage in Air Travel
  • How to Measure Luggage
  • How to Expedite Lost Luggage Claims
  • What Are the Dimensions of Hand Luggage for Air France?
  • What Rights Do I Have If My Luggage Is Lost?
  • How to Store Luggage While Traveling in Italy
  • pixel.gifHappy Camper: Test Your Outdoors Knowledge
  • pixel.gifCruisin' Along the PCH: Test Your Knowledge
  • pixel.gifWhich U.S. Landmark Would You Be?
  • pixel.gifCan You Pass for a Proper Brit?
  • Nov 15, 2014 | Lands Phones
    Tsa002 change combination
    Most combination luggage locks can be reset when they are open. The combination wheels can't be turned unless the lock is being reset. So either the wheels show the correct combination, or you will be able to turn them to a new combination. The lock that is "locked outside the hole" was either not relocked after inspection or it's in reset mode.
    Jul 04, 2014 | Locks & Locksmithing
    I previously set my combination and it worked fine. Now my combination will not work on my cal pak lock luggage. how can I open now and reset combination?
    Try rotating the numbers on the combination dial three times to clear any previous entry (stop on the zero's if this applies) and enter your combination one more time to see if this works and gets it open.
    The default is 000; to set it, hold the lock open, move the dials to your numbers, and close/open three times. This will set the combination to your numbers.
    Aug 27, 2011 | Locks & Locksmithing
    HOW TO CHANGE LOCK COMBINATION IN A SAMSONITE LUGGAGE OYSTER GL
    I forgot my locker combination and my luggage is locked.How can I open it??
    Nov 13, 2010 | Samsonite Silhouette 11 Hardside Spinner
    Set luggage lock
    the lock is currently set to 000. To set your own combination and with the lock in the 000 position, open the case and on the inside of the lock mechanism you will see a red tab. slide this tab to the left and then move the digits on the front to your desired code. ie 123. then move the red tab back to lock in this new setting as your own personal combination. close the case and then move the digits away from our setting of 123 and this locks the case. only if the digitrs are 123 in this example will the lock now open.
    Dec 24, 2008 | Locks & Locksmithing
    Locks & Locksmithing Logo
    3,621 people viewed this question
    Top Locks & Locksmithing Experts
    john h
    Tom Chichester
    Andrew Taylor
    Andrew Taylor
    Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
