Question about OKI C Office Equipment & Supplies
How to reset drum life on OKI C830 - C OKI Office Equipment & Supplies
Rikkes
    New Friend:
Does not work on OKI C830. Get error message such as toner level error.
Posted on Sep 23, 2015
5 Related Answers
Anonymous
SOURCE: How do you reset the OKI c5800 drum?
You don't need to go through all that mess of replacing the fuse. The tone gets everywhere and getting the Drum unit back together with all the gears and shafts lining up is a real pain.
The Drum reset system is very simple. When the printer powers up and runs through its system check, one of the tests energizes the erase LED array built into the Drum unit. The reset fuse routes a small amount of low voltage current off this LED array. There is a contact on the end of the Drum unit that the printer senses. It there is voltage there (ie the fuse is good), the printer resets that Drums counter to 100%. If there is no voltage (ie the fuse is blown), the printer continues on its way.
All you have to do it act like fuse at the instant the printer sends power to the LED array.
There's no soldering, no screws to undo, and no toner all over the place.
The best thing is it takes about 3 minutes start to finish and cost $0.00!
Here's what you need:
• A simple volt/amp meter (an analog one works best, but digital is fine also) • Two pieces of thin wire about 300mm long. I used old telco wire. With insulation, its about 1mm wide. • A pair of scissors to strip the wire ends • X-acto or thin razor knife
1) Strip about 4-5mm off the one end of each wire and 25mm off the other end. Bend the 5mm end at a 90 degree angle right at the base of the stripped part. 2) Pull out the Drum unit (leave the toner cartridge attached to the Drum unit) 3) On the right end of the Drum unit (DU) there are three square brass contacts about 3mm wide. The right end is the end with the blue handle. Looking at the end of the DU, you are interested in the 1st and 2nd contacts from the left (they are the two closest to the screws on a c5800 cartridge) 4) Use the X-acto knife to lift the contact metal and slide the 90 bent end of the wire under the contact. Do this with the other wire on contact #2. 5) Put a little vertical tension on the wires and route them around the blue toner release handle. 6) Gently insert the DU/toner cartridge into the printer. Keep slight tension on the wires until the unit is seated. 7) Wrap the 25mm stripped end of the wires around the volt meter leads. Wrap one so it makes electrical contact, but you could pull it apart instantly at the right time. 8) Set your voltmeter to the lowest amp setting. I put mine on 200micro amps. Also make sure your voltmeter leads are in the correct holes of the voltmeter. You want the amperage or milliAmp holes not the voltage holes. Don't forget to turn the meter on. 9) Get prepared to pull one of the leads off of the one of the thin wires and turn on the printer. Don't be afraid to touch the metal of the wire; the voltage/amperage supplied to the LED array is very low and will not hurt you. A 9 volt flashlight battery is more dangerous. 10) About 10 seconds into the startup routine, you will see you voltmeter display a reading. Instantly pull the leads apart.
Congratulations, you are now officially a 1/16amp fuse.
Your printer will reset the Drum Unit counter and you have another 20K impressions (if the image quality is acceptable to you)
If you have any question, just respond to this post. I'll get the email and answer you.
Good Luck.
Paul
Posted on May 22, 2010
Joe Fine
  • 628 Answers
SOURCE: OKI c5600 drum reset
It usually resets automatically when you replace the drum/toner units. Are you trying to get it to reset before it's supposed to? I don't know of any way you can do that.
Posted on Apr 20, 2009
Tim Swiercinsky
  • 1126 Answers
SOURCE: OKI c5100 flashing "K drum life" across screen. what does this mean?
"K" drum refers to Black drum Apparently the black drum has reached its life expectancy and needs to be replaced.
Posted on Jun 07, 2009
Anonymous
SOURCE: oki b4600 drum reset ?
On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE!!!!!!!!
Posted on Jul 09, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: OKI C8600 Replace Image Drum - 563: K Drum Life
Solution:
  • Power on printer while holding both the + & - buttons simultaneously; release when “OKIUSER” is displayed.
  • Press either the + or – button until “ENGINE DIAG MODE” is displayed; press the Enter button and “DIAGNOSTIC MODE xx.xx.xx” will be displayed.
  • Press and hold both the - & On-line buttons simultaneously until “ENG DIAG LEVEL2” is displayed.
  • Press either the + or – button until “CONSUMABLE COUNTER SET” is displayed, press the Enter button; you are now in the menu to set various consumables.
  • Press either the + or – buttons to scroll through the various consumables, at the desired consumable press the Enter button and the last digit of the count will start flashing.
  • Press the Cancel button to decrease the digit amount or press the On-line button to increase the digit amount; press the + or – buttons to move along individual digits in the count.
  • Once the count is at the level you desire, press and hold the On-line, Cancel, & Back buttons simultaneously until the “*” reappears next to the count; consumable’s count are reseted to the number you specified.
  • Press the + or – buttons to move to the next consumable and repeat at step 5.
  • Once all consumable counts have been set to desired amounts that are below their end-of-life thresholds, you can use the Back, +, & - buttons to exit through the menus
  • until “INITIALIZING” is displayed.
Posted on Jan 30, 2010
OKI B410dn drum life
Every Oki B410d printer, Oki B410dn, Oki B430d, Oki B430dn, Oki B440dn, Oki MB460, Oki MB470, Oki MB480 are contacting the module of the Oki 43979002 drum and fuse with chip developed in the module imaging unit through joints being in the bottom part of a printer like in a photo. Eksploatacja Oki B410 pochodne drukarki reset kasowanie bbna
Jan 28, 2014 | Oki Electric Industry C8600n Led Printer
Message saying drum unit life on OKI PRINTER C510dn
This model OKI printer is not an inkjet printer, it is a color laser printer. and uses color toner cartridges.
The printer image drum unit has reached the end of its service life and this drum unit needs to be replaced.
I suggest you Google the Internet for an OKI image drum unit for your model printer, You will get various suppliers and their prices.
The image drum unit will cost approx. A$200
Feb 07, 2013 | OKI C5100n Laser Printer
I HAVE C5500 OKI PRINTER AND THE ERROR SAYS REPLACE IMAGE DRUM 561:M DRUM LIFE I PUT IN NEW MAGELN AND STILL HAS THAT MESSAGE
oki printer c5950 fix new cartridge & drum coming error replace image drum 561:m drum life
Jan 15, 2013 | OKI C5500n Printer
OKI C6100 has the following error when printer is turned on: Replace Image Drum 562:C Drum Life
Try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
Nov 11, 2009 | OKI C6100dtn Led Printer
How to reset black drum counter OKI C3300 ?
Buy a pack of 10 x .062A (1/16A) pico fuse RS part No 738-3062. Switch off printer. Remove the drum and toner together from the drum slot to be reset. Carefully crimp the legs of the fuse around the contact wires on the right side of the drum slot. Make sure fuse legs are making a good connection to the wires and aren't touching the frame. switch on printer and allow it to detect the absence of the drum. Switch off printer and carefully remove the now blown fuse. Re-install the toner and drum assemnbly. Drum life is now reset. see pic:
Sep 15, 2009 | OKI C3400n Laser Printer
OKI B6300 DRUM/TONER
try this:
6.Press Ready
Jul 28, 2009 | OKI B6300 Laser Printer
Oki C5450 error message
The figure after the K drum Life tells you how much life there is left on the BLACK (K) drum. C indicates Cyan, M indicates Magenta and Y indicates Yellow.
Go to the USAGE MENU and look at the K DRUM LIFE setting. This will be a 2 digit percentage value. As you have just seen the message appear this will mean that the drum life remaining is ....whatever the 2 digit value displays.
The life expectancy of a drum is approximately 15,000 pages.
Jun 08, 2009 | OKI C5400 Laser Printer
How can I reset my Drum Life Counter on my Printer?
http://my.okidata.com/PP-B4250.nsf?opendatabase
Guide Users: B4250 download user manual
American English
May 06, 2009 | OKI B4250n Laser Printer
I would like to reset the drum counter of my OKI 8800
You need to insert a 1/16A fuse into the drum and let printer blow it thus resetting the counter. Don't use fuses with the higher rate - they can easily blow your printer instead! Much more expencive that putchasing a new drum. By the way - 20k at continuous printing, meaning print jobs are as big as 100-200 pages each. The less pages per job the sooned drum life ends up.,
Mar 05, 2009 | OKI C8800dn Led Printer
Oki c5400
Drum life for C5400 is roughly 15000 pages
Feb 09, 2008 | OKI C7350hdn Led Printer
2,407 people viewed this question
Top OKI Office Equipment & Supplies Experts
Alvin Barnabas
Alvin Barnabas
Timothy Van Der...
Mike
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
