Question about Pinnacle Televison & Video
How to use EPG
I cannot get information regarding the use of EPG. After I configure the program guide and download the channels I get a list, which I never see again after I continue to the next step.
So what is the purpose of EPG. Please help.
Thank you for your assistance
P.S. I use the Pinnacle Pctv Pro Hard Stick(801e)
Posted by me1stalboy on
Vernon Taylor
  • Pinnacle Master
  • 6,666 Answers
EPG or Electronic Programme Guide is the on-screen version of a tv guide for digital tv. The remote control usually has a dedicated button for the display of the EPG.
The information displayed is often incomplete and some digital boxes or tv sets perform better than others though in theory it needs no setting up. Once the box has searched and made a channel list the programme guide will be available.
Posted on Nov 17, 2017
5 Related Answers
Anonymous
SOURCE: I have a tv tuner card pinnacle studio PCTV pro 4.0 my driver CD
which top of the range tv tuner you can recommend for my pc( FUJITSU, Pentium 4, 3 ghz, 512ram
Posted on Mar 06, 2009
Anonymous
SOURCE: Pinnacle PCTV pro stick 801e
Hi Adam,
Here is the link for tv center pro for your vista 64 bit download and install this to your computer. http://cdnexpress.pinnaclesys.com/akdlm/SupportFiles/TVCenter/TVC540/PinnacleTVCenterProSetup_5.4.0.3032.exe.
I suggest also to connect your tuner device at any usb port.
By the way you need the serial number for the new tv center pro.
Enjoy.
Posted on Apr 07, 2009
Anonymous
  • 447 Answers
SOURCE: my Pinnacle PCTV HD Pro Stick (801e) USB TV Tuner isn't working
This page contains drivers for all of the Pinnacle TV products, scroll down to 801e (if that is indeed your model) and select the appropriate OS download. The instructions should be in the zip file...
If you still have problems post additional info under this thread so we can follow up with you.
Posted on Apr 18, 2009
Anonymous
  • 1027 Answers
SOURCE: I Just installed my 801e pctv stick on th atenna
Check the configuration menus - they should have an orientation setting area.
Posted on Jul 24, 2009
TommyF DISH
dish
  • 263 Answers
Delivering video anywhere, anytime.
    Verified Fixya Pro
    SOURCE: Hello, Some of the channels on
    Hello, Tommy Faust with DISH Network here. I'm sorry your guide is showing you incorrect information.
    What may fix it is a hard reset where you unplug the receiver from the power outlet for 15 seconds and plug back in. If that doesn't work then try a check switch test. Go into Menu - 6 (System Setup) - 1 (Installation) - 1 (Point Dish) and select check switch then select test.
    If you are still having the issue or any further questions feel free to ask here.
    Posted on Jan 08, 2011
    Is there a TV Guide for the ematic AT 103B digital converter box?
    There is an electronic program guide. However, it's limited. To see the current program and upcoming programs for the current channel, press the EPG button on the original Ematic AT103B remote. (Universal remotes may or may not match the function.) To see the other channel's program list, use the left/right arrows to scroll through the lists for all of the available channels.
    You may find a web site like Titan TV, http://www.titantv.com/ , more useful. The site has a guide to all channels at once by time for your area OTA channels.
    I hope this helps.
    Jul 29, 2018 | Televison & Video
    Why don't i have the tv guide when up until 7 pm tonight i was getting it...now it just shows data unavailable
    try changing channel number of TV to channel you are interested in finding in Electronic Program Guide and wait for 30 seconds for data to get downloaded into EPG
    Apr 27, 2018 | The Computers & Internet
    I bought a LG tv model# 22LG3DCH and I cant program the chanels it says no signal but other tv pics up just fine.How do I fix it?
    [PDF]Commercial Mode Setup Guide - LG.com
    www.lg.com/.../32ld345h-commercial-mode-setup-guide....
    LG ElectronicsThe model and serial numbers of this TV are located on the ... However, there is noguarantee that interference will not occur in a particular ... the TV by the hanging power and signal cables on the back ..... program guide (EPG) data provides additionalchannel and program ..... If set to 1, cannot tune from current channel.
    How to resolve the No Signal or No Channels in Master List ...
    ? 2:07
    https://www.youtube.com/watch?v=Tk7EUAEncsQ
    Oct 6, 2014 - Uploaded by VIZIO
    How to resolve the No Signal or No Channels in Master List message. ... Show more ... Why Does My TV Say ...Missing: 22lg3dch
    LG TV "No program information" - HDTV - Streaming Video & TVs ...
    www.tomsguide.com/forum/55640-4-program-information
    May 24, 2012 - 7 posts - ‎5 authors
    I bought a 35" LG TV a few months ago. ... TV on and it was (and still is) displaying "No program information" instead of ... All other information about the current channel is displayed OK. ... Diamondhead said: ... Can't find your answer ? ... a LG Sound BarModel LAS350B to a Toshiba TV Model 32C110U1?
    Jan 05, 2016 | LG Televison & Video
    TV guide Panasonic Viera
    Try updating the software. It might cure the problem.
    Aug 09, 2017 | Televison & Video
    Problems on epg information on some channels but not others
    Is the episode guide from OTA channels or a set-top box (Tivo, cable)? Make sure that the time is set correctly. In my area, the automatic time information comes from the OTA PBS station. That station's time often is off by a few minutes. (Similarly, when the time is set manually, the clock also drifts on one of my TVs.)
    If you get your information from a set top box, try rebooting (or unplugging for a minute) the unit. This sometimes will reset the data.
    If those two suggestions don't help, the problem is from the stations/EPG provider. Sometimes the provider's clock is off and this causes the issue. You could try contacting that provider if their clock or program list is routinely off. (If this is related to an event that took longer than scheduled, there isn't much to stop the issue.)
    I hope this helps.
    (Last weekend, my cable box had the correct time. The EPG insisted on showing the programs for 5-6 hours later. Since the provider is a local cooperative, we had to wait until Monday for the support staff to reset the EPG at their computers. Rebooting the set-top box was tried, but didn't help.)
    Jun 30, 2014 | Televison & Video
    The GUIDE button on the remote (model EN-33926A) for a Hisense 55K610GWN does not work
    my children messed around with the remote and now i can turn the tv on from the actual tv but from the remote when i press channel up or down or hdmi buttons it turns the tv of.. remote model en-33926a
    Dec 19, 2013 | Hisense Televison & Video
    Tv won't work
    I downloaded this off of Wikipedia. You are not the only person having the problem with the switch to digital television. The complaints are nationwide. the old TV Guide Plus has gone away for many viewers and soon for all viewers as the transition to DTV gets nearer. If you are using an antenna be sure to get the digital converter. They are practically free with a government sponsored coupon.
    Digital television
    The new service, launched in the United States in 2006, is entirely digital, using the ATSC digital television standard. While this will significantly improve the service, older systems will no longer be able to download listings once analog shutdown is done in early 2009.
    It should be noted that the Program and System Information Protocol (PSIP) within the ATSC standard already allows for each station to send out its own EPG information, and in the U.S. the FCC in fact requires stations to do so for OTA (but not cable, unless they are rebroadcasting an OTA station that provides the PSIP data). However, actual implementation is rather spotty, and usually very minimal -- stations often don't have full descriptions (or even correct information) on the current show, much less the next 3 hours required of them, or the 16 days worth of guide information that can be transmitted. Additionally, ATSC tuners are not required to even show the EPG, only the very limited information for the current show on the current channel.
    While the TV Guide service also requires software in the TV or other device, and licensing fees or royalties to be paid to Gemstar TV Guide, it also offers a more complete solution for broadcast television, more like digital satellite or digital cable.
    Nov 28, 2008 | RCA 20F420T 20" TV
    Guideplus problem
    EPG fix here
    http://www.fixya.com/ThreadView.aspx?prdid=221926&thid=1696771
    Nov 27, 2008 | Philips HDRW720 DVD Recorder
    Pioneer dvd recorder dvr-530H
    The EPG is the electronic program guide trying to download TV listings.
    http://en.wikipedia.org/wiki/Electronic_program_guide
    This is normal for this player. To disable this, you would need to turn off the TV guide function.
    Sep 28, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
    Open Questions:
    Televison & Video Logo
    155 people viewed this question
    Top Pinnacle Televison & Video Experts
    Muntejaya Ginting
    Muntejaya Ginting
    Tom Chichester
    Lawrence Oravetz
    Are you a Pinnacle Televison and Video Expert? Answer questions, earn points and help others
