I turn my tv on and it just shows a rainbow color effect, from bottom middle of screen to the top two corners for a couple seconds then shuts off. If I smack the tv around and tip it forward sometimes it will work... dont know what the deal is!
SOURCE: RCA 27F520 Shutdown after a few seconds
you have lost the vertical ic and maybe resistor or capacitor.
but you also maybe loosing the horizontal ic
you will also have to check the voltages on the flyback transformer that go to those circuit's to see if they drop or are correct
SOURCE: my 36 inch RCA tv has black bars on the top and
as a general rule, vertical faults can be divided into two types: ones that cause geometric distortion (a circle will not be round) and those that simply black out a portion of the screen. the former are faults in the vertical oscillator, drive, or output stages. the latter are blanking faults. blanking faults are almost always caused by electrolytic capacitors changing value and thereby changing the timing of the pulses which blank the screen during vertical retrace. In other words, the pulses are turning off the video signals at the wrong time. the most common true vertical fault is geometric distortion and a foldover of white lines at the top of the screen. this is almost always caused by the electrolytic capacitor on or near the collector of the vertical output transistor or part of the IC which has the supply voltage (B+) on it. In the old tube days, the general rule was that bottom distortion was in the cathode of the output tube and distortion at the top was caused by a fault in the drive circuit. this may help the solution!!
SOURCE: Hi, I have a RCA 61
try to resolder all bad cold solder and open ones
see if this helps good luck
SOURCE: Picture seems sunk in and the color distorted with doubleing effe
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
CONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
SOURCE: Can't turn on T.V. @ sign comes on.... next to Channel #03
front panel lock has to be unlocked with original remote....try mrremote.com punch in model# ..........good success...........Meder's tv service
