Question about HP ProLiant DL380 G6 Server
Check event viewer for Window. Insight Manager (if installed) for HP related problems. Type server name or IP on browser. examples: 192.168.2.1:2301. Localhost:2301. 127.0.0.1 again local.
Posted on Aug 28, 2012
SOURCE: ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Try to look at this Guide & Manual on "HOW TO"
Just let me know..
Hope my initial idea/info helps you..
Thanks,
micro
Posted on Jul 25, 2008
SOURCE: Hp compaq prolaint dl380 g4
Even with out the display, can you ping it from the network? If not I would power off the server. Unplug the power. Take the cover off the server, reseat the memory. Pullout the both power supplies and reseat them. remove any cards in the server except the disk controller. Reseat all the disk drives, make sure you put them in the same slot you pulled them from, even though it doesnt matter. Plug back in and see if you get a display. You can move the memory around also or take out some. If you are not getting an intermittent beep or a red display on the front panel, your system board may be shot.
Posted on Jun 25, 2010
SOURCE: how can i boot my hp dl380 g6 server in safe mode
Different system use different F keys to get to safe mode, If F8 is not it, try F10.
Good Luck
C2Solutions
Posted on Mar 05, 2011
Oct 20, 2012 | HP ProLiant DL380 G6 Server
Oct 15, 2012 | HP ProLiant DL380 G6 Server
May 19, 2012 | HP Compaq ProLiant ML350 G4 Server
Nov 15, 2011 | HP ProLiant DL380 G6 Server
Oct 06, 2011 | HP Compaq ProLiant DL380 G4 Server
Sep 20, 2011 | HP ProLiant DL380 G6 Server
Feb 14, 2011 | HP ProLiant DL380 G6 Server
Dec 18, 2010 | HEWLETT-PACKARD HP ProLiant DL380 G6 X5570...
Mar 18, 2017 | HP Computers & Internet
381 people viewed this question
