My reverse action will only turn 1 way but if i pull at the belt it will slowly move then stop like something is stopping it from going round and its giving off a burningb smell
SOURCE: Hotpoint condenser dryer ctd00
change the drive belt. evidently the belt has stretched to the point the belt tensioning device can no longer do its job. when you change the belt make a diagram of which way the belt is reaved through the tensioning device. if you don't you'll be back here asking how to arrange the belt.
SOURCE: smells like somethings burning, more
did the drum stop turning,when motors overheat they smell realy bad.
SOURCE: Hotpoint Aquarius TDL30 tumble dryer timer not advancing
fmw76:
This could be a timer issue or a thermostat.
If you are using a timed dry it would be timer .
If you are using an auto dry cycle it would possibly be a thermostat.
woodychoppers
SOURCE: DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up. Start windings are ok. replace motor.
SOURCE: Burning Smell from Belt on Whirlpool Dryer
Hi, You need to check and see if the belt has slipped off of one of the pulleys. Was the idler the wheels style or a glide style?
Make sure the grooves in the belt are facing the drum and they are in the grooves of the motor pulley.
Please let me know if this helps and if I can assist you further.
Vic
1) Verify a circuit breaker
isn't tripped
2) Advance the timer
control dial slowly 360 degrees-
If the washer starts
spinning, then we know the motor and drive belt are
fine but that there is something wrong with either the timer control dial or
the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is
attached and not broken by removing the back panel. If the belt is broken,
replace it. If it is loose, then tighten it by loosening up the bolt holding
the motor and moving it on its swingarm (much like a car alternator) until
there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin
cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid
safety switch- Is it loose or cracked?
If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
