Question about RCA F32450 32" TV
Tv is stuck on scrolling thru the menu and inputs front, 3, svid 1 and svid 2
1 Related Answer
Anonymous
  • 837 Answers
SOURCE: tv on but cannot use remote
Have you tried unplugging it for at least 5 minutes?
Posted on Jan 10, 2009
Menu segreto hannspree hsg1113
http://translate.google.com
Secret service menu Hannspree HSG1113
https://electronicshelponline.blogspot.com/2015/03/hannspree-lcd-tv-how-to-enter-service.html
Possible menu - Quoting from link above:
SERVICE MODE [Hanspree AT06 42" LCD TV] (Horizontal Frequency 31.5KHz to 48KHz)
* In the TV mode, adjust volume to Zero and press number keys 9 > 8 > 7 > 6 to enter service mode.
* To exit, press the EXIT button on the remote control.
SERVICE MODE (Hanhspree GT02 32E - GT03-37E1)
1 Switch on the LCD TV .
2 Press 9-9-1 on the remote control to enter the internal Service menu.
3 Press MENU to switch the service mode pages.
4 Press ?? to scroll through the various menu options.
5 Press ?? to change the menu settings.
6 Press MENUto save the new settings and switch to next page and press EXITto exit from service mode to normal mode.
TV / AV / S-VIDEO / WHITE BALANCE / BRIGHTNESS & CONTRAST ADJUSTMENTS
WHITE BALANCE ADJUSTMENT
1 Press 991 on the remote control to enter the internal Service menu.
2 Press MENU to switch to the PW106 Scaler Menu page
3 Press ?? to scroll to Page 2-3 options
4 Press ??
to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings.
5 Press EXIT to save the new settings and exit. [Don't adjust others setting in page 2-3]
Click on the Pictures to Zoom In
BRIGHTNESS ADJUSTMENT
1 Repeat the above mentioned step 1 to 2
2 Press ?? to scroll to PW106 FE VDC Menu Page 2-1 options
3 Press ?? adjust the Brightness setting.
4 Press ?? to scroll to TV/AV/S Parameter=AV1 setting and pressuto run the setting. (This procedure will copy the settings of AV1 to S & TV)
ATSC DTV WHITE BALANCE / BRIGHTNESS / CONTRAST ADJUSTMENT
2 Press ?? to scroll to PW106 Scaler Menu Page 2-3 options
3 Press ?,? to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings
4 Press to save the new settings and exit. [Don't adjust others settings in page 2-3]
YCbCr & YpbPr of COMPONENT 1, 2 WHITE BALANCE/BRIGHTNESS/CONTRAST ADJUSTMENT
Getting COMPONENT-1 connect to 1080i signal. (The settings could not be saved if signals input from COMPONENT 2 or connect to other sources such as 720P, 480P, 480i,etc.
WHITE BALANCE ADJUSTMENT OF Component
1] Repeat the above mentioned step 1 to 2
2] Press ?? to scroll to PE106 FE ADC page 2-3 options
3] Press ?? to adjust the Offset Red and Off Blue settings.
4] Press ??to adjust the Offset Green setting.
5] Press ?? to adjust the Gain Green setting.
6] Press ?? to scroll to 480i/480P/720P Parameter=1080i setting and press ? to run the setting. (This procedure will copy the setting of 1080i to 480i/480P/720P)
7] Press EXIT to save the new settings and exit.
WHITE BALANCE ADJUSTMENT OF PC INPUT
1.Connecting to VGA Timing mode
2.Under service mode, Press ?? to scroll to PE106 FE ADC page 2-2 options
3.Press ?? to adjust the Offset Red, Offset Green and Off Blue settings.
4.Press ??
to adjust the Gain Red and Gain Blue settings.
5.Press EXIT to save the new settings and exit.
May 14, 2018 | Hannspree Televison & Video
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers ยท Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
The store demo mode is stuck on my insignia tv. the user guide says go to menu and then setup and select plug & play. however the plug and play option is grey and it wont let me select it.
Are you using an HDMI cable? Go to input and select TV. Then you should be able to access the Plug & Play option and be able to turn off the Demo Mode.
Jan 03, 2011 | Insignia 42" Flat-Panel Plasma HDTV
Have RCA HD50LPW42 Projection TV and the RCA Jacks stopped working both the rear and front mounted. I took it to a TV Repair shop and the guy told me to reset the TV. I looked through the manual when I got...
Go to Menu see if it List Reset Factory settings.
Try with TV off/ Press and Hold ch- and vol- on TV.wait untill TV comes on release buttons and see if Service Menu comes up?
Mar 29, 2010 | RCA HD50LPW42 50" Rear Projection HDTV
Menu Screen pops up, try to exit and goes to video 1
This could be a stuck button on the front control panel or a bad solder connection on one of the switches on the front control panel.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Please Help !!!!!!!!!!!!!!!!!!!
1. hit menu, use right arrow and select 'Audio'.
2. hit menu use down arrow to scroll down and select 'Speakers'
3. hit right arrow to scroll thru options, select 'on'
4. hit menu 3 times to save and exit back to picture
Jul 28, 2008 | Panasonic CT-36D32 36" TV
Toshiba 36a40
Double check that the Demonstration in the menu is not set to on. This will cause it to keep scrolling thru.....
Jun 10, 2008 | Toshiba 36A43 36" TV
Operating a SONY DVD player with RCA TV
The only thing I can think of is that you have the input option on the wrong input. Have you tried pushing the input button or TV/Video button? I hope it helps...
Feb 23, 2008 | RCA F27664 27" TV
No picture with vhs
Don't pass the video sample through the Onkio.. Use a second single RCA patch cord to go from vcr to TV... Use the same yellow out on the vcr that you're using now and send it directly to the yellow video input you're using on the TV..
Hope that's clear - I'm getting tired...
Bill
Dec 02, 2007 | RCA TruFlat 27F520T 27" TV
RCA F32450 32" TV Logo
23 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
