Question about Olympus Camedia Cameras
SOURCE: Olympus Camedia C-310 Zoom Digital
If you're running Windows XP then you don't need it. Connect via USB cable, switch on the camera (to view) and press the OK button when the menu appears. The camera will then be seen in windows explorer as a drive and the files can be copied direct to your hard drive. You can then use a better software package to store, view, manipulate and print them.
Posted on Dec 18, 2007
SOURCE: Olympus Camedia 4.0/ C-4000 Zoom and Windows Vista Operating System
Doubt the software will work on Vista. If you do have the disk, before you click on the install program, right click it and use the "XP compatability" mode. I would dual boot to an XP partition to take care of all your XP needs. Its a bummer but that is what Im doing...
Posted on Feb 25, 2008
SOURCE: zoom lever (Olympus Camedia C-8080 Wide Zoom Digital Camera ) does not work
If you can get to the ribbon cable that the zoom lever is attached to, you can use a multimeter or a continuity tester to see if the lever is actually shorting any traces on the ribbon. the zoom lever acts upon a motor that rotates the iner lens barrel, possible the motor lead is open or the switch under the lever is dirty/faulty.
Posted on May 11, 2008
SOURCE: Cannon Olympus Camedia C3000 Zoom
Hi - You can download the manual from the link underlined in blue below:
Camedia C3000
It's in 3 parts
More info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 26, 2008
SOURCE: instuction manual for a Camedia Digital Camera C-725 Ultra Zoom
Hi - You can download the manual by clicking the link underlined in blue below:
C-725
Informatica
Posted on Sep 11, 2008
