Question about Toshiba Satellite M60 Notebook
Toshiba m60-104 screen dark new screen new iverter
New screen and new inverter fited but screen is still dark new install of xp
Posted by Harry Spratt on
General Systems Consulting
    Top Expert:
  • 5,051 Answers
Have you tried an external monitor?
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the display shows on the external monitor that proves your video card is ok and your lcd screen is the issue. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If is shows on the external monitor, then you would have to question if the new screen and lcd inverter is bad. Just because they are new don't mean they work. Are you sure you purchased the lcd screen and inverter that is for your model?
Posted on May 24, 2012
1 Related Answer
mahabishara
  • 81 Answers
SOURCE: new lcd screen for p30/35 is showing very dark?
check the settings in :
start...control panel... toshiba power saver.
see the disply brightness and drag the rule for the wish point for you.
also the same setting can be done when you press Fn+F7
note that FN is a button in the keyboard located between ctrl and alt.
hope it helps .
Posted on Nov 29, 2008
Display fades away and colores waile reading
Replace it with a new LCD Inverter, you can address the following issues:
Screen image, but the power light stays in
Dark display, but still readable
Flashing on and off of the screen between 1/2 to several seconds
The power indicator stays on, but no display and sound
Screen images, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
More information in: http://lcdinverter.info/toshiba-lcd-inverter-c-13/
Feb 26, 2013 | Toshiba Satellite Computers & Internet
Toshiba laptop satellite A75 dim screen
The used inverter maybe faulty. The inverter supplies high voltage to the CCFL lamp in the LCD screen, the CCFL lamp provides the backlight.
LCD screens and Inverters are available from this WEB site.www.lcdparts.net
Feb 15, 2012 | Toshiba Satellite A75-S226 Notebook
Your Question My Toshiba Satellite m115 will boot up but the monitor wont light up, you can see the images in the back round but the screen is dark. if i connect to external monitor the external monitor...
Diagnosis:
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
Oct 07, 2010 | Toshiba Satellite M115-S3094 Notebook
Cracked lcd screen. Found a lcd replacement without the inverter. What does an inverter do? do I really need it? Can't i just take the one on the previous lcd screen and apply it to the new lcd? and just...
The inverter is the source of all the "brightness" of the LCD display. So, unless you use your laptop in a totally-dark room, you need an inverter.
I would try your current inverter, to see if it works, before going out and trying to find/purchase an inverter.
May 13, 2010 | Toshiba Mini NB205-N313/P Netbook
Screen dark unable to adjust/ external screen works fine.there is a 1/2" x 6" board just below the screen w/ #41095 on it. that board is falling apart, i need a new one
There are plenty of the screen inverters on Ebay, just search by the computer model number, not the inverter part number. They should be about 20 bucks with shipping. That is why your screen is dark, the inverter takes power from your power inverter and converts the DC power to AC for the LCD backlight. Yours sounds like is failing or failed.
Jan 27, 2010 | Toshiba Satellite A60 Notebook
My dads toshiba A20-S207 has a dark monitor. Can very faintly see the windows xp logo at the beginning of boot up, so it looks like it is booting up, but the monitor stays dark. Can u help?
common LCD dark.dim screen problem, u can google keywords get more information.
either LCD inverter failure or CCFL backlight lamp failure, ask for a pro get it fixed.
by using a flashlight could you see the image on the LCD?
Dec 06, 2009 | Toshiba Satellite A20-S207 Notebook
Toshiba L350D Screen Loss
you may plug off remote monitor power on to see carefully is there normal dark picture on your lcd screen,
!) lcd dark but there is pcture on the screen, it means the back lights inverter damage(which in the lcd lid and downside of lcd panel), or lamp damage (in the lcd panel), have to replace new parts
2) no any picture and dark panel, you may check lcd signal cable plugs are right seat in the sockets (which located between the back of lcd panel and motherboard), also check the inverter cable same thing (it merges in LCD cable) . it is better replace a new cable (most cases are cable disconnection somewhere)
is this helpful please feedback when you checked, iwill tell you what you can do next, thanks
Feb 15, 2009 | Toshiba Satellite Pro L300D-EZ1002X...
LCD starts to display for about 2 seconds then goes dark.
lamp(s) perhaps.... with an LCD monitor (the desktop kind) you can shine a lite behind it. if you can see things on the screen it's the lamps... if you can't it's something else.
Robert
Aug 28, 2008 | Toshiba Satellite 1135-S125 Notebook
Toshiba m55-s135 screen
Hi
Problem with you laptop inverter replace it has shown in pic...
Thanks
Jun 16, 2008 | Toshiba Satellite M55-S135 Notebook
Toshiba P205D
either screen or viedo card has gone out try plugging it into a alt screen and see if it shows or not if it does I would say your screen took a floop or if it does show on a atl screen I would suggest you have prombally lost your veido card let me know la la linda
Jun 02, 2008 | Toshiba Satellite P205D-S7479 Notebook
Toshiba Satellite M60 Notebook Logo
82 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
