Question about Electrical Supplies
Getting Rid of Disposer Smell
Our disposer has had a lingering smell that we can't seem to get rid of. We've tried ammonia, baking soda, vinegar, and nothing worked. Is there some other way of getting rid of these smells
Posted by jeer weezer on
Gene Haynes
  • 5,391 Answers
Remove and clean trap underneath sink.
Then flush disposal and tubular drain with hydrogen peroxide
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Jun 30, 2012
5 Related Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: BADGER GARBAGE DISPOSAL just humms. does not work.
It sounds like the disposer has something jamming it. Try using the breaker wrench supplied with the disposer (or a suitable-size hex wrench) fitted into the socket on the bottom. Rock the wrench back and forth to see if you can loosen the jam. Another trick is to use a wooden rod (end of a broom handle, for example) to push on the blade to try dislodging the jam. Look inside with a flashlight to see if there is something that is easily missed. (I have found drink can tabs, coins and a shelf clip that way.)
It's also possible the motor starting capacitor inside the disposer or the motor itself is bad, in which case you would probably spend less on a new disposer than on repairing this one. But a jam is more likely.
Posted on Jan 28, 2009
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: garbage disposer drain pipe is lower than the p-trap
Sorry you are doomed. The only other way to install is to have a plumber come back out and lower the drain in the wall.
Posted on Sep 10, 2009
Fred Yearian
  • 5603 Answers
SOURCE: badger 5 garbage disposer does not grind
Some say to put a load of ice cubes in and run it.
Posted on Dec 30, 2009
Mike258
Justin Case
  • 1498 Answers
SOURCE: My Ace 2000 is very loud, like their is a fork in
Jim,
You are exactly right. Knife, spoon, fork , whatever. that metal on metal sound is produced in the flail chamber.
Get a flashlight and have a look inside.
Needle nose pliers can be handy for extraction.
Mike
Posted on May 30, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: The power was working fine but water was back up
Check the reset button...
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
Posted on Sep 29, 2010
What makes a kitchen sink stink?
There can be several reasons behind stinking of the Kitchen Sinks. Here is the list of them and the tips to resolve them:
  • A rotting food smell from junk stuck in the garbage disposal or drain: Use vinegar and baking soda, run ice cubes through the disposal, put lemon or orange slices in the disposal.
  • Sewer smell from gas leaking in through the drain trap :High pressure can force its way through the water in the trap and low pressure can siphon out the water from the trap.
  • Bacteria: One reason for a smelly kitchen sink can be the presence of bacteria in the drain pipe. To get rid of the bacteria you can either use baking soda, vinegar, or a commercial drain cleaner or bleach.
Even if you do not get rid of stinky smell then you can contact any professional plumber online for help.
May 30, 2018 | Home
How to get vinegar smell out of ac window unit
hi Jeff.
not saying this will work,but its all i could find on the internet.
Sprinkle baking soda on the surface being cleaned (as long as it is safe to do so). Scrub with a sponge or plastic brush to work in the baking soda. Rinse with clean water and the vinegar smell should disappear.24 Dec 2009
How to Get Rid of a Vinegar Smell ' Hunker
https://www.hunker.com/12001359/how-to-get-rid-of-a-vinegar-smell
What will neutralize the smell of vinegar?If the smell of vinegar lingers and you just hate the smell, open a box of baking soda and leave in the room that smells. The baking soda will neutralize the smell of thevinegar.What are some ways to get rid of the vinegar smell without removing ...https://www.quora.com/What-are-some-ways-to-get-rid-of-the-vinegar-smell-without-re...Search for: What will neutralize the smell of vinegar?
How do you get the smell of vinegar out of a car?Sprinkle baking soda over the carpet before vacuuming it to remove odors.Blot the area affected by the vinegar if it is still damp. ...Sprinkle baking soda over the affected area of carpet and let it sit for about an hour.Vacuum the carpet thoroughly.Reapply more baking soda and vacuum again if necessary.How to Remove a Vinegar Smell From Carpet ' Hunkerhttps://www.hunker.com/13421004/how-to-remove-a-vinegar-smell-from-carpetSearch for: How do you get the smell of vinegar out of a car?
or go to this link might help you out more.
How to get vinegar smell out Google Search
Nov 26, 2017 | Heating & Cooling
I'm getting a horrible sour/sweaty like smell blowing out of my Henry when vacuuming, i've tried to clean the filter, but its still just the same & the smell also seems to be in the head o
You can buy little sachets of nice smelly stuff to put inside Henry. Most supermarkets have them. Makes the carpets smell nice too.
Feb 07, 2013 | Henry Vacuums
I have a lettuce smell in my refrigerator
Most of the time the smells get into the insulation on the unit and is near impossible to get rid of. You might try arm and hammer to keep the smell down.
Mar 11, 2012 | GE Refrigerators
Odor coming from disposer
Hello, Tell your husband to wash his feet some place else, OK. it needs to be cleaned. Don't put you hand in it, OK. On the top in sink remove the rubber flapper and clean it with soap water and vingear. Put about four large cups of ice and tuirn on the disposer. The ice clean out any stuff that in the chopping blades. Mix up a sink of water, soda and a little clorex in the disposer sink then let the sink drain and turn on the gargage disposer then let it run while water is running into it. Do a cleaning procedure once or two a month. couple of lemons, Clorex, baking Soad, this stuff will work great. It will make you disposer smell like fresh spring day but tell you husband to keep his feet out of the kitchen sinks. GB...stewbison
Sep 24, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage Disposal Ace 2000 model 47982.... The water won't drain out of it and the sink is backed up and hasn't gone down for a whole day now. It seems like the blades are turning. I've been...
Hi David,
Are the blades actually turning or is just the motor running?
First, turn off the power to the disposal at the circuit breaker. Do not put your hand in until you do this.
If you hear the motor running, but not the blades, then the blades are jammed. On most disposers you can put an allen wrench in an opening under the unit and move the blades. If the blades move freely, then your drain line is probably plugged.
If the motor runs, but the blades don't and they will move freely by hand, then the disposal needs repair.
If the blades are jammed with food, you can clear the jam with your hand and the allen wrench trick from underneath.
Once the disposer is freed up, run cold water down the drain for a few minutes to harden any grease build up inside. Then running the disposer should get rid of the hardened grease.
By the way, most disposers have a reset button on the bottom of the motor should your disposer jam and turn off or trip your breaker.
Orange peels, etc. will not harm your disposer. A good way to keep it clear is to put egg shells down it periodically. The shell action will scrape junk off the inside of the disposer.
You can also keep the disposer clean of grease buildup by pouring some baking soda in the disposer followed by a mix of hot water and vinegar.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 06, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Best way to get rid of smell in a used freezer is? What
Personally, I have used bleach & warm water solution to scrub out interior.....then rinse thoroughly....followed by drying thoroughly. Now place a box or two of Baking Soda in freezer (depending on size) and close.
Jun 11, 2009 | Frigidaire Freezer FFU2124
Had standing gray water under house got the water out and fixed the drain problem but still have the smell How do we get rid of the smell of the stagnent water its bad. Thanks
Many commercial cleansers are good for neutralizing odors, but several common household products can be used as well. Vinegar is an extremely versatile grocery item that neutralizes many odors, including those left behind by pet accidents and skunk sprays.
Baking soda, whether applied dry to an area or mixed and sprayed with warm water, is another effective way to absorb and neutralize household odors. Baking soda carries the added benefit of absorbing moisture, so it often makes a good secondary application for a moist stubborn stain causing an odor. Citrus fruits like lemon and oranges deodorize and leave a pleasant smell behind. Using citrus juice on fabrics is not usually recommended, but they are good for things like running through garbage disposals.
May 11, 2009 | Dishwashers
GE spacemaker xl1800 microwave "burnt paper" smell
Hey
There are several things you can do to help git rid of that smell
First get a mild cleaner with bleach (soft scrub ect!) and clean entire oven inside and try getting that scorch mark off! a little pressure should lessen it ! (there is no filter inside! The plastic inside covering holds smells for a long time! you can also put a cup of white vinigar inside warm on high for 1 minute and leave in overnight!
Please take a second and rate my response
Thank You1
Jan 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Electrical Supplies Logo
125 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
