SOURCE: Xerox Phaser 6125 Color Printer
I called Xerox and it seems that it's because the imaging unit is defective. They are seeding me one free of charge. Hope you can do the same...
SOURCE: replace waste cartridge on Xerox Phaser 7400
I just fixed mine. You need part #604K47890 Gear Coupling Assembly Kit. Cheapest I found was $6.99 at www.sparepartswarehouse.com plus $13.95 s/h. Remove the waste cartridge & you can see the white plastic gear. I tried to disassemble the printer (using service manual) in order to replace this part. Good luck. It looks like you need to take the WHOLE thing apart. Easier method is to get a drill or dremel & grind away the thin metal to make the whole slightly larger. Just be careful with the dust/particles. I did this & it worked perfectly.
SOURCE: Waste Cartridge Full
The optical sensor looks at a small compartment, that has clear walls; when the waste toner gradually fills the container, it eventually reaches the level above a "wall" between the main container and this small compartment, spills inside and makes not transparent anymore. Some toner might have gotten there and the sensor gives a false full signal. You can get rid of it by cleaning this compartment with compressed air.
Obviously, the sensor might be plain broken as well, but the above is perfectly true - it saves the day when the printer stops and we don't have a new waste container... I pour out the toner and clean the inside thoroughly with compressed air, especially that small look-through compartment.
SOURCE: Xerox Phaser 3100 Reset solutions, no need to
we have module to reset xerox 3100 permanently
www.nakshatraworld.com
SOURCE: Hello, how to reset toner cartridge for xerox
Through Module we can resetted Xerox 3100 permanently.
