Question about Leviton Electrical Supplies
Electrical gfui reset keeps popping out. Located on patio.Does not lock[n position.
Posted by LARRY SCHAEFER on
Gene Haynes
  • Leviton Master
  • 5,391 Answers
There is a short, or GFCI outlet is bad.
Copy following links for help with GFCI:
http://waterheatertimer.org/pdf/GFCI-outlet-will-not-reset.pdf
http://waterheatertimer.org/How-to-wire-GFCI.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Jun 30, 2012
Need help with ignition switch on 2002 grand prix..keys stays in got it out try it again and sticks in again.
Does the vehicle start an run ?Can you turn the key to the off position ? And the key won't come out ? Did you try some key graphite ( lube ) ? New lock cylinder need maybe . Or is it a problem with
Steering Column Electric Park Lock
If the vehicle is equipped with a floor-mounted console gear shifter, an added safety feature is an steering column electric park lock system in the steering column. The steering column electric park lock system prevents the steering wheel from being locked when the transmission is in gear and the vehicle may be moving. The column ignition lock system consists of a steering column electric park lock and a park position switch, that is located in the A/T shift lock control switch. The steering column electric park lock contains a spring-loaded pin that mechanically prevents the ignition key cylinder from being turned to the Lock position when the transmission is not in the Park position. If vehicle power is lost or the transmission is not in the Park position, the operator will not be able to turn the ignition key to the Lock position and will not be able to remove the ignition key from the column.
Oct 30, 2017 | Cars & Trucks
Camera is somehow "card locked"
The SD memory card should be located where the rechargeable battery is, remove battery cover, should be a small tab holding the memory card in place, move it so the card pops up, remove it and look along the one edge for a switch, slide it towards the contacts to unlock the card. The switch that is furthest from the contacts is in the locked position. Now if you find the card is in the unlock position, slide it back and forth to reset, failing that replace the memory card. Sometimes the slider switch becomes defective locking out the card.
Aug 15, 2011 | Cameras
I have a 2006 f-150 1/2 ton extn cab. the electric windows quit working. I am convinced it is a fuse on the main feed. Where is the fuse for the windows and what size ? The electric locks work fine.
There is a 30 amp circuit breaker. The concept of the circuit breaker is to "pop" when there is an overload but is supposed to reset after a bit. That is not always the case or you could have a short in the wiring of the windows cicuit which also includes the rear sliding light. If that is the case of course it will keep "popping" But like I said I have seen them get weak and just replaced them. The location of that circuit breaker is in the passenger compartment fuse panel. It will be in the number 401 position. I gave you a diagram of the fuse layout below. I hope this helps and good luck.
Jun 02, 2011 | Ford F-150 Cars & Trucks
Have Challenger Type C 2100 circuit breaker in residential home electrical panel. Manually turned to off position and now cannot turn back on. Pops back to off position. Also says HACR type and common trip...
First HACR is heating, air conditioning,refrigeration. So in other words you could use it on an electric furnace or air conditioning.
IS this the main breaker for the panel? or for and electric furnace. I'm assuming its for the furnace, perhaps back up heat for heat pump. See if there is another disconenct on the furnace, turn it off and see if the breaker resets. IF so you have a short or overload in the furnace.
If' it IS the main for the panel, turn off all the other breakers in the panel, and try to reset the breaker. If that works, turn the other breakers back on one at a time. IF it "POPS" then it is tripping. Don't keep resetting, find the problem.
Jul 19, 2010 | Challenger Connecticut Electric UBITB-A230...
Does the Char Broil PAtio caddie come with bricquets?
No, it does not. Here is the complete parts list for your patio caddie:
Patio Caddie Parts
  • Electric Patio Caddie Heating Element
$22.00
  • Patio Caddie Ignitor Electrode
$4.19
  • Patio Caddie Burner Shield - Heat Distribution Plate
$10.75
  • Single Pole Snap-In Ignitor Push Button
$5.25
  • Patio Caddie Ignitor Wire
$2.50
  • Patio Caddie Top Lid Handle
$10.50
  • Patio Caddie Hardware Kit
$8.15
  • Electric Patio Caddie Aluminum Top Insert
$37.50
  • Electric Patio Caddie Aluminum Bottom Insert
$37.50
  • "Grease Catcher" Hanger Wire and Cup
$4.50
  • Patio Caddie Cooking Grate
$29.00
May 17, 2010 | Grilling
When i closed my gas door it locked, how do i open it?
There will be a release inside your car. I'm not positive where it might be, but the most common place for a volvo seems to be somewhere on the passenger door. If it's not there it may be on the dash, below the driver's seat, center console.
Aug 19, 2009 | 1994 Volvo 850
Actually it's a DPAC 13009. We need to extend the 2 air pipes 4 to 5 feet each to reach upper windows over patio doors to keep doors locked and secure. Does Danby provide air pipe extensions? Thanks.
No solution possible, given that the air ducts going up over the patio doors are quite an eyesore. This building is entirely fieldstone outside, so either the patio doors or windows above them are the only way to go in or out.
We will return the unit and get instead one that can be placed in the upper window and activated by remote control. Thanks.
May 16, 2009 | Danby DPAC12031 Air Conditioner
I have a Coleman Patio heater. The flames are very yellow & I don't believe it is sending as warm a flame as it should. Would like to know how to adjust air intake or similar to alter this. I am a...
The primary air adjustment is located at the burner inlet. To little air and you have yellow flame. To much primary air and you get flame lift off from the burner. The adjustment may be locked in position by a screw. To change the adjustment you must loosen the locking screw.
Sep 14, 2008 | Coleman Heating & Cooling
Electrical Supplies Logo
146 people viewed this question
Top Leviton Electrical Supplies Experts
jdthefixer
Gene Haynes
john h
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
