SOURCE: polaroid i733 digital camera lens stuck open
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the batteries. (obvious I know).
2. The camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
SOURCE: i can not fully insert
Are you using the right type of card?
I'm not familiar with the camera you mention but generally speaking digital cameras nowadays use the thinner XD cards which are also not as big as SD cards. If your camera is made to use SD cards and you cannot get such cards into it, then take it back to the shop you bought it from and ask them either to show you, or sort out the problem, as it will be under warranty I presume
Dave
