I need the software to download pictures from a trail camera, Windows XP or Linux 12 operating system.
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
You don't need to use a driver.
SOURCE: Request for Operator's Manual
All the Moultrie camera manuals available via PDF =>
http://www.moultriefeeders.com/ProductInstructions/GameCameras/default.htm
If not listed, try calling them (800) 653-3334 or (205) 664-6700 Monday through Friday 8am to 5pm Central Standard time.
SOURCE: Camera doesn't recognize the sd card, bypasses it
1) This camera accepts SD cards up to 4 GB in capacity. Most 4 GB SD cards however, are "SDHC" types (check the label to determine which type you are using). If you are using a 4 GB "SDHC" card, it may be causing the problem, as it is not an "SD" card. Furthermore, any card greater than 4 GB is not compatible with the camera. Any SD card with a capacity less than 4 GB should work without issue.
2) Check the position of the lock or "protect" tab on the side of a compatible SD card to be sure it is in the unlock position. The camera will be unable to write to a locked or protected card.
http://www.moultriefeeders.com/Game-Spy-D40
I hope this helps!
SOURCE: I am in need of an operators manual for Moultrie
Here is your manual:
http://images.ebsco.com/pob/Moultrie/catalog/DGS-D40-User-Manual-compressed.pdf
