Question about Vizio P2 42 in. HD-Ready Plasma Television
Vizio sound bar remote not working - Vizio P2 42 in. HD-Ready Plasma Television
Posted by stephen fortlouis on
Jane Doe
    New Friend:
Unplug the sound bar for about 10 seconds.
Posted on Feb 15, 2015
John S
    New Friend:
My sound bar does the same thing. To get the remote to work unplug the power cord from the sound bar and then plug it back in. This is the 2nd sound bar from I bought with problems. I'm thinking I may have to return this one too.
Posted on Mar 06, 2015
Lou G
    New Friend:
Enjoyed Vizio 38" Sound bar S3821-w-CO for about three weeks but now the small remote will not turn on bar nor adjust volume etc. Checked batteries and changed 3x but still not communicating to sound bar from 6-8 feet away. Just stopped working for no reason last night after being fine. Does it need to be re-booted or ? Bought at SAMSCLU. Appreciate some directions, HARV
Posted on Jan 31, 2015
2answers
Vizio sound bar 2.0 remote control not working
After only three days I would take it back, or at least take the remote back and try it on a different sound bar.
2answers
Where is the fuse in a vizio sound bar
It can be located at the main power supply section.
2answers
I Have a 5.3 IR Remote and a vizio VSB200 Sound Bar. The remote will not program to the Sound Bar. The Optical Audio is connected to the TV. What do I need to do.
lojr,
We have code to use with amplifiers, TVs, VCRs, and DVD players. I do not have a code that will work on this sound bar. What is the code you are trying to use? Did Vizio supply a code with your sound bar. They do have codes to use for their TVs to program DISH remotes. Please let me know if you have a code or you can contact Vizio to see if they have a code available.
I have provided the Power Scan instructions on programming the remote to a sound bar. Use the VCR button to attempt to program the sound bar.
If you have further questions, please post it here.
Ray Calo
DISH Network - Executive Offices
Power Scan Instructions Power Scan Instructions
1. While at the sound bar location, point the remote at the sound bar. Press and hold the VCR MODE button on the remote until all four MODE buttons at the top of the remote light up.
filestream.ashx?id=435
2. Press the RECEIVER POWER button on the remote.
filestream.ashx?id=436
3. Press the UP ARROW on the remote, about one press every two seconds. Stop as soon as the sound bar turns off. This process may take several minutes.
filestream.ashx?id=438
4. Press POUND (#) on the remote. The VCR MODE button will flash three times.
filestream.ashx?id=440(VCR button instead of TV button)
5. Press VCR MODE button, then red TV button on the remote to turn on the sound bar. Press VOLUME on the remote to confirm the remote controls the sound bar. If this does not work, return to Step 1.
filestream.ashx?id=442
Remember to press the SAT MODE button to return to the Satellite mode to change channels.
2helpful
3answers
Need dish code for remote for vizio soundbar
Hey there, this is Cheri Torres with DISH Network customerservice. I wanted to see if I could help you with the question you posted aboutthe Vizio sound bar. I was unfortunately not able to find any codes for theVizio sound bar. Another option you can try is running a channel scan to findyour code that will work best to control your sound bar. I hope that theseinstructions are useful to you. If you have any further questions or concernsplease feel free to post back here or email me at [email protected]
Remote: All Remotes (except Basic)
    1. With the desired equipment on, press and hold the correct Mode button until all mode button back lights illuminate, then release.
    2. Press and release the Power button. AUX Mode: Before pressing and releasing the Power button
      • Press 0 for a TV
      • Press 1 for a VCR/DVD
      • Press 2 for any other device.
      Then Press STAR (*)
    3. Press the Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, the equipment will power off.
    4. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
1helpful
2answers
I just bought a vizio sound bar and am trying to program it to work with my mitsubishi tv remote. I cant seem to find any codes for it. would u happen to know where i could find them at?
I found code 1517 for the Vizio sound bar for Comcast and a universal remote- I don't know if codes for your remote are 4 or 5 digit codes, but this is the only one I found that works. Hope it helps.
2helpful
I am looking for the code for my Visio Sound Bar to program into my Dish Network remote to the AUX button. Has anyone talked with Visio Support to get this code? Thanks.
ronwright22
I have provided a link for you to Vizio's Website. The information below is for a VSB210WS sound bar. I would go to this link and research your model number and look for the code. You may try the code on this screen to see if it will work. I have also provided a link with instructions on programming your DISH remote to other components.
Vizio Website:
http://www.vizio.com/vsb210ws.html
This is the VSB210WS sound bar.
Programming a Universal Remote to operate the HD Sound Bar System If you own a VIZIO TV with a Universal Remote that uses a 5-digit programming code, you may program a device button with code 31517. This will map the Universal Remote button to operate the HD Sound Bar System as follows: Pictured at right is the VIZIO VUR8P Universal Learning remote.
Ray Calo
DISH Network
27helpful
4answers
Looking for remote codes for vizio sound bar and comcast remote
I have a vizio universal remote and the code that works the vizio sound bar is the first one listed under audio/vizio 0660
Vizio P2 42 in. HD-Ready Plasma Television Logo
Top Vizio Televison & Video Experts
Ekse
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
