Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN  All-In-One InkJet Printer Logo
nigel france Posted on May 23, 2012
Can i send a fax without ink? - Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN All-In-One InkJet Printer
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 07, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
587
Points
My fax machine is a Canon mx860. it would not let me do ANYTHING without a black ink cartridge, even tho all the color cartridges were full (black can be made without a black ink cartridge, it just waste your color ink a lot.)
Since it was an emergency i scanned the document to fax from my desktop as a .jpg file, sent it to my laptop containing a modem, and faxed it from my laptop with windows 7's "fax and scan wizard". I know its not a fix, but its an emergency work around.
  • Anonymous Nov 07, 2012
    my fax machine is a Canon mx860. it would not let me do ANYTHING without a black ink cartridge, even tho all the color cartridges were full (black can be made without a black ink cartridge, it just waste your color ink a lot.)
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
1helpful
2answers
CAN I FAX IF THERE IS NO INK IN MY CARTRDGES
You should still be able to send fax without cartridges in the printer since it does not require printing. Receiving fax w/o cartridges is not possible though.
Why are all my incoming faxes all black pages?? Is it my fax or the senders? Very hard on the ink cartridge
hard to determine the problem without any make/model of your fax machine. However I would begin by looking at the fax contrast and darkness settings, they are likely cranked to the dark side. If you cannot find these settings or this doesnt help. post your make/model information. I don't believe this should affect sending faxes, its likely just a print / contrast setting for received faxes.
Cannot send and receive fax after refilling PG-40
I own a Cartridge World ink refilling store and I think that the fax not printing is Canon's new approach to kick out refills from their all in one machines. We cannot reset the ink level indicators on these cartridges and if people can no longer print faxes if their ink says it's low, then they can never use refills if they want to use their fax machine. I think it is also a way for Canon to make more money on their ink sales by making consumers buy new ink before theirs runs out. As far as I know there is no way to fix this problem.
1helpful
Error messaage "unable to clean" on a MFC210c
There should be a number with the error, if it's 46, you need a new ink flushing box. You won't be able to fax until you clear the error.
1helpful
Can't send fax because of message: Ink Empty Black-Replace Ink
No, the machine needs to have all cartridges installed to perform all actions, including fax and scanner functions.
3helpful
Can you send a fax without black ink
of course, ink is only needed when the machine needs to print something on paper
Error
You should be able to send out a fax on there without replacing the cartridge.
14helpful
3answers
My canon mx310 wont allow me to send a fax, it says 'waiting for report' when i press send.
I have the solution for this problem. You need to go into your fax settings, and adjust the RX Settings. There is an option there to "print if no ink" and you set that to YES, and it will spit out the pending report that is preventing you from sending faxes.
old marine
old marine
ZJ Limited
ZJ Limited
