Checked wiring in box all ok. but cannot find solution to the 3 lights on at the same time.
Circuit analyzer does not show all possible problems, and tester might be defective.
Use analyzer on other outlets.
Buy another circuit analyzer.
Buy a multimeter at local hardware, and test for voltage, and continuity, and compare with known outlet that are functioning correctly.
For example outlet may be 240Volt instead of 120V.
Copy following links to see typical circuit analyzer and code:
http://waterheatertimer.org/images/Typical-circuit-analyzer-15.jpg
http://waterheatertimer.org/images/Outlet-polarity-200.jpg
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: wiring a 3 way switch on 1 plate to 3 lights and 2 other switches
I have a light switch at the bottom of the stairs which works 2ways can be switched on and off up and down stairs and also an out side light on the same switch which I have messed up and would like a picture of the way it should be connected.
SOURCE: Connecting Leviton Decora light switch.
At the switch you have a feed wire coming in this brings in power which originates in the electric panel. You also have a feed or feeds goings out to other lts or switches, this you seem to have on the switch. instead of the closet switch loop.undo all the wires. find the only hot this is the one wire you can touch to the others and make different lts come on i reccomend getting a electric tester to do this. FInd the wire that goes to the closet lt. Once your sure put it to the side. wirenut all other wires together with the hot wire. this makes all other switches independantly hot. connect the hot to the switch and the closet lt to switch. I HOPE THIS MAKES SOME SENSE TO YOU . let me know if i can help
SOURCE: I need to wire a 3 gang switches in a 3 gang box
before u start make sure power is off before working with electrical lines ---start with the 12/2 coming into box black [power] white [ground-neutral] and u will have 3 separate lines for the lights so u will have 4 lines total coming in the box== with the 3 light lines take the white and strip back the plastic and connect [wire nut] all 3 to the 12/2 white line --now take the 12/2 black line and connect it to the first switch gold color screw- bottom screw -now take some wire about 2-3 inch strip both ends and connect from the 12/2 black wire connection on the switch and connect to the gold /bottom of switch 2 than do the same for switch 3 connecting the wire from switch 2 so u will have power feeding all 3 switches-- now connect the black lines for the lights to the other side of each switch and ur done
SOURCE: I'm using a Leviton 1755 combo 3 switch for a bath
remove white switch one and connect to incoming white ground--all whites should be connected [hooked] together these are grounds-- switch 1 black from fan ,leave switch 2 red from fan ,switch 3 vanity black
SOURCE: The 3-way dimmer switch has 4 wires; 1-red,
Incoming white - outgoing white
This is the neutral, which just passes through without connecting to the switch
incoming black - switch black
the hot wire provides power to the switch
switch red - outgoing red
a traveler, will have power when toggle is one position
switch yellow - outgoing black
the other traveler, will have power when toggle is in the other position
incoming bare - switch green - outgoing bare
the switch is grounded and it passes through
If this was helpful, please vote.
6 pin socket
6 pin plug
7 pin
socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug
& socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin
round plug & socket
1 left hand turn - yellow
2 reverse -
black
3 earth -
white
4 right hand turn - green
6 stop - red
7 tail, clearance, side
markers - brown
round socket
large 5 pin round plug & socket
3 earth -
white
5 right hand turn -
green
6 stop - red
markers - brown
large 7 pin
round plug & socket
2 reverse -
black
3 earth - white
6 stop - red
markers - brown
7 pin round
heavy duty plug & socket
1 earth -
white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
5 right hand turn -
green
6 right hand rear , clearance and marker - brown
7 reverse/auxilary -
blue
7
pin flat plug & socket
2 reverse -
black
3 earth - white
6 stop - red
markers - brown
flat socket
12 pin flat
plug & socket
2 reverse -
black
3 earth - white
6 stop - red
markers - brown
8 battery supply -
orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
