Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Lamp on hitachi 50v500a is in the back
I can see lamp in back,,pull down front door no lamp compartment How to I replace lamp that is in back of tv
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
Been a while since I saw one of these sets--part of a class action lawsuit==if I remember lamp is behind a door that is clearly removed from outside of set--check or google here the model number with lamp location and You Tube has video instructions for changing the lamp itself.
Posted on May 23, 2012
6ya staff
SOURCE:
ienvyno1
SOURCE: Lamp Replacement Problems for Hitachi 50V500A
I'll tell you what I tran into and how it got resolved...
I experienced the same problem , with the blinking light...
Purchased a replacement lamp..
It didn't work(After market Universal supposably)..
Well..Come to find out.The Replacement lamp's housing looks similar, but the connecters that come out the back of the housing weren't quite long enough to trigger the microbe that activates the lamp in the Television.
Luckily I had the original lamp and it's housing that came with the television..
Took the bulb out of the new replacement lamp
Placed it in the original housing , and BINGO..It worked and is still working...
Posted on Jan 16, 2008
George Allison
  • 31 Answers
SOURCE: hitachi 50v500a lamp light
"Yes" Or the lamp door on the set is open!, "Check lamp" most of the time the lamp will pop & fail... you will see this by looking at lamp
Posted on Jun 30, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Hitachi 50V500A Lamp
Lamp replacement procedure is written on page 69 to 72 in user manual of Hitachi 50V500A TV.
Lamp cover is at front of TV, requires to unscrew it then lamp needs to unscrew and pull out lamp.
If you need user manual copy, please download it from Here.
Posted on Oct 03, 2008
Anonymous
  • 10 Answers
SOURCE: I have a 50' Hitachi model 50v500a The lamp light
Light engine issue
Posted on Feb 21, 2010
Anonymous
SOURCE: Hitachi 50V500A cooling fan for LAMP doesn't turn off
After i replace the lamp on my Hitachi50v500a worked everything then i turn it off.After 1h wanted to turn it on again and it shows (TEMP) light is that a lamp fan or something else.Please help how to fix it by my self.Coz no money to call the tech.
Posted on Jun 24, 2010
Hitachi 50v500a: Lamp blew, oredered a replacement. Just installed it, and I still get the "lamp" light on and it wont power up.
Remove lamp and look to see the socket the lamp plugs into did not get bent out of position---just check to see if it went in right and after that you put the door back(set will of course not operate if door or cover removed).
If we assume New lamp good and installed correctly the next possible issue is the Ballast which powers the lamp--Not easy on this set to check voltages---should have a plug with over 200-300 volts from power supply going to--the two wire plug from the lamp goes directly to it.
Apr 04, 2012 | Hitachi Televison & Video
How to install lamp
Here is a link to Hitachi DIY LCD TV Bulb and Lamp Installation Guide. It shows the 50V500a and 60V500a lamp location and bulb replacement. Check your user manual for information regarding safety and bulb disposal issues.
easyab
Feb 23, 2011 | Hitachi 60V500 60" Rear Projection...
Replaced the lamp on my Hitachi 50v500A but it does not work. I put the olf one back in and it still works.
It sounds that new lamp is bad, return it and get replacement.
This can happens with new lamp.
Sep 23, 2010 | Hitachi 50V720 Television
Where is the lamp located on my 50v710 Hitachi TV
The lamp is located behind the lower removable speaker grill on the front of the TV. There will be a lamp door then the lamp is up inside the TV behind the lamp door. Make sure the lamp door is back in place before turning on the TV after replacing the lamp as the set will not work without it installed.
Mar 02, 2010 | Hitachi 50V710 50" Rear Projection...
Cant locate the lamp in my hitachi 50v500a
your lamp is in the lower left hand corner, You must first remove the plastic front cover. You will see a door with screws on the lower left, remove the screws and the lamp will come out easily. When replacing it wear latex gloves and avoid touching the lamp as this will shorten the life of the lamp.
Sep 14, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Aug 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Oct 03, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50v500a lamp light
Jun 30, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Don't know what is going on
Check the door lamp switch & lamp pwr switch, boss on the door or lamp assy may not close switch. apply tape to boss
Mar 15, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
50V500A
if the lamp has dies alot of the time to can look inside the lamp and see if it exploded (not always) do you get blinking lights?
Feb 01, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
62 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
