There is no power to my stereo cd, tape player and clock
Hi margie, your fault lies with the power line feeding both your clock and car radio units. check the fuse of the line feeding your radio/clock section. the fuse box should have the areas clearly marked. also check if the ground connection to radio/clock is not diconnected sumhow. if this advice does not help then it wub advisable for you to consult with nearest auto-elecrician. cheers.
SOURCE: 2001 Ford Taurus Radio doesn't work but CD player does!
Possible Antenna Disconected ? Or Plain Radio FAILURE Seen this Before and Radio Muse be Replaced, IF it"s NOT Antenna
SOURCE: I have a 2000 ford taurus ses my radio, tape
You might try testing the power that leads into the insturment panel. You can remove the hole radio assembly by bending a wire coat hanger enough to get it into the two holes on the sides. When you pull it out, you will have depressed a couple of clips. The power switch is connected to the left side in the back of the unit. Hope this helps.
SOURCE: 05 Ford F150 Radio doesn't work.
it needs to be programed to your vehicle. we have to program every replacement radio we install at the dealership. only takes a few mins.
SOURCE: i have 97 for ranger with tape deck with cd player
This should help you wire up your new stereo. 97 Ranger stereo wiring diagram. They do make a plug in harness for your truck. Metra part number 70-5600.
For Radio related problem,the help links are below.Click the link below to go through its procedure:-----Car radio works but CD player not working?http://technoanswers.blogspot.in/2012/02/car-radio-works-but-cd-player-not.html-----------How to reset Radio code after car battery is died?
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
------------- Can car radio code block Passkey anti theft system ?
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
How to wire new car Radio?
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
Radio Stereo Wiring Diagram?
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
How to remove radio on Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
Where is Radio Fuse located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
----------- After Market Stereo wiring?
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
car radio doesn't allow to switch to the XM Band to get the radio ID?
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
No power to radio Scion Xb?
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
Radio has power but no sound?
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
Radio goes ON and OFF while driving?
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
Town Car Radio stereo wiring?
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
Radio wiring diagram for Car?
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
How to remove cd player from dash?
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
This will help.
Thanks.
