THQ Biggest Loser Ultimate Workout for Xbox 360 Logo
william hill Posted on May 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I log in. It asks if the date appearing on the screen is correct and if not to change it. It says if it is correct, hit bthe advanve or continue botton...there is no button, font, etc to select shown on the sceen. nor do any of the controllers buttons advance the game to the next sceeen.
Tor-Erik Maseide
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 117 Answers
  • Posted on Jan 21, 2013
Tor-Erik Maseide
Expert
Level 2:
New Friend:
Cheetah:
Answers
117
Questions
0
Helped
23572
Points
187
When it asks you to continue, It is either the A button, or the Start button, if neither, you should be able to continue somehow by using Kinect.
Heloo sir i have a problem with my dell 170l when i start it it shows ''strike F1 to continue, F2 to run the setup utility'' when i click f1 it show ''f1 to retry boot,f2 for setup utility'' plz help me...
Hit F2,look in setup to see if the hard drive is recognized and check that the date and time are correct.
Then hit esc key. it will ask if you want to save changes, click yes. It should boot and probably ask you to hit F1 or F2 again., unless there is a problem with the CMOS battery, which may need to be replaced.
If you hit F1 to continue, it will boot, but your time and date will be off.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
I am trying to change some settings in the port forwarding. When I go to save it ask for my log-in info. But it will not recongnize me. I know I am using the correct log-in info because I am IN. I have...
1. try typing the user/ password into a word pad or to see if you have caps lock on
2. just try typing "admin and leave the password blank and hit enter.
3. If you are still unable to enter properly then reset the router to default and establish
new user information for the router.
When i open window it says password and then i want to reset it
between the lines from your English ...am I to understand that you have the log on screen where its asking for your password and not logging in with welcome screen at once ...to remove that you have to go to the control panel ...at the user accounts ..open it ...and click on the acount you use..not on the guest one ...after that click remove my pasword..
.and if you do not have a password..but that screen is still appearing even if you can log on after you hit enter ..without the password..just when you open the user account in the control panel ..instead of clicking on the user...click on the line that says change the way user log in .. ..click ..the line that says use the welcome screen ..and thats all..
If the password thing is not a full screen but a rectangular loging that asks for user and password..than you have to go to the local area connection (the 2 monitors in the task bar ) .. double click on it ..after that properties...and in that list with the protocols..you have to remove the NETWARE service ..by clicking on it ..and after that remove ..
this will allow you to change the way users log on from the panel like I explained above...
2answers
I can not log to my account on my laptop and login passward is also correct but it shows only loading on screen
I suspect a problem with windows Hit the F8 key during start up of windows and choose safe mode then log on, also log on to admin acct just in case your acct does not have admin rights to check device drivers and the logs in windows, of interest would be the applications log very useful in
finding problems. if that fails use the recovery console during boot or boot from the recovery CD and choose to fix windows.
Need to change the time
You weren't precise if the change was due to Daylight Savings Time or just a general need to change the time so I'm giving you the complete set of instructions for changing the time
Setting the Time
Note: Use 24 hour and 60 minute format when setting the time.
For example: 2:00 pm = 14:00.
1. To make changes to your clock’s time setting, you must first put the clock into Program mode. See
section Accessing Program Mode to Update Calendar, Time and DST for instructions. When the
display flashes P1 dAtE, press the ◄ left button until P2 CL oc appears, then press the ● right
button.
2. Press the ◄ left button to choose 12-hour AM/PM display or 24-hour military time, then press the ●
right button.
3. Press the ◄ left button until the correct hour appears, then press the ● right button.
4. Press the ◄ left button until the correct minutes appear, then press the ● right button.
5. When the display flashes the correct time, press the ● right button.
6. The display flashes P2 CL oc again. To make changes to the DST start date or DST end date, press
the ◄ left button one time until P3 BDLE appears in the display and continue to How to Set the
Begin Date for DST. Otherwise, press the ◄ left button several times until END appears, and select
the ● right button to save your updated settings.
How to Disable DST
To disable Daylight Saving Time, set the DST beginning date equal to the ending date (i.e., DST begin
date = 08-03-09; DST end date = 08-03-09).
See next for details regarding setting the DST begin date and end date. Typically, clocks operating in
Arizona, Hawaii and Puerto Rico do not observe DST, and disabling the DST function typically applies to
those areas only.
By default, and unless otherwise modified, DST takes effect on the first Sunday in April and ends on the
last Sunday in October (this was the United States standard through 2006).
How to Set the Begin Date for DST
Note that in 2007 the standard for DST changes to a different start date and end date. The steps below
correct the change in the new start date for DST. The new start date and end date need only be changed
once, since the clock’s rolling calendar function auto-calculates the start date and end date for DST every
year thereafter.
Note that if the begin date for DST has passed, in addition to modifying the begin date (and end date),
you will also need to modify the time.
1. When the display flashes P1 dAtE (see earlier section Accessing Program Mode to Update
Calendar, Time and DST for instruction), press the ◄ left button until P3 bdLt appears, then press
the ● right button.
2. Press the ◄ left button until the correct year appears, then press the ● right button.
3. Press the ◄ left button until the correct month appears, then press the ● right button.
4. Press the ◄ left button until the correct date appears, then press the ● right button.
5. When the display flashes the correct year, month and date, press the ● right button.
6. When the display flashes P3 bdLt, press the ◄ left button once to select next menu option, P4
EdLt, which provides a way to set the end date of the Daylight Saving period.
Setting Daylight Savings Time for model PIX-10/15/21
Page 4 of 4
How to Set the End Date for DST
correct the change in the new end date for DST. The new start date and end date need only be changed
year thereafter.
1. When the display flashes P4 EdLt (see conclusion of previous section How to Set the Begin Date
for DST for instruction), press the ● right button.
6. The display flashes P4 EdLt again. Press the ◄ left button several times until END appears, and
select the ● right button to save your updated settings.
Note: To disable the Daylight Saving Setting, set the beginning and ending date to the same date.
2helpful
How do I get the date to print on the pictures
To set datestamp to appear on your pictures:
Hit FUNC SET (middle of wheel on back)
Hit Right side of wheel to SELECT the mode you would like to have (Auto, Man, etc)
Hit Bottom of wheel to get to bottom of Left Menu on screen
Hit Right side of wheel to SELECT fifth selection (Postcard 1600x1200)
This is the only mode I have found that supports the date stamp on the Canon Powershot SD600.
P.S. Don't forget to set the correct date and time in the screen MENU under the Tools tab!
15helpful
4answers
Changing Time
Hey peoples this worked for me :)
On the main phone
- hit the "PROGRAM" key
- then key in **
- it asks for a password key in 1234
- then key "NEXT"
- then key "ENTER" (this is to set the date)
- then key "NEXT" (this is too set the time)
- once the time is correct hit the "ENTER" key at the bottom of the phone.
97helpful
13answers
Setting Bench Watch
Reset Instructions Bench. (BC0013BR)
Time and Location
If you hold in the light, start and the reset button for a few seconds a screen will appear with the 12h or 24 h clock setting and also the date and country.
Once you have that screen if you press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time.
Once you have changed the date and time to the correct date press the light button, start button and reset button and it will save the settings.
Alarm
Hold in the light, start and the reset button for a few seconds a screen will appear
press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time. Use the light button to set the screen.
Feb 27, 2008 • Watches
ETrex Vista shows incorrect date
Thanks for the great advice. My problem is fixed!! Yay!
Top THQ Video Game Consoles & Games Experts
ZJ Limited
ZJ Limited
MegaByteMe
MegaByteMe
Are you a THQ Video Game Console and Game Expert? Answer questions, earn points and help others
