Having problems getting power to the amp
Hi robert, attach your remote wire from the amplifier to the blue/white striped wire of the harness of your kenwood unit. the wire should be labelled "p.cont". cheers!
No vork antna sistem and spiker
It will be blue/white. If not then try the blue wire. Make sure the blue wire doesn't lose voltage when you turn to a source other than the radio.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
SOURCE: how do i get my kdc-138/cr out of the demo mode?
press the center of the control knob for 2 sec
each time you press it will turn off or on the demo mode.
SOURCE: Don't know how to set clock on kenwood kdc-138 without manual
change the tune mode to standby mode. Then press menu button for few second until clock word is displayed on the screen. Afterward, press the center of the main control button on the right side of the stereo system. The time is now blinking and you can start set the time by pressing upward & downward button for hour and left & right button for the minute
SOURCE: intalling my kdc-138 in a honda
the brown wire is for a cell phone mute...to use with a hardwired car kit, and the blue/white is for a power antenna. orange ...is this from the car harness?
Testimonial: "Thank you "
SOURCE: kdc-mp522 locked
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The
procedure to enter your security code differs on various models of
Kenwood car stereos. Here are three of the more common procedures:
Type 1
During
the code request mode, while holding the DISP key depressed, press and
hold the Volume UP or DOWN key for 3 seconds until the "..." display
disappears.
Enter the security code using your Kenwood remote.
Type 2
Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To
enter a letter using your Kenwood remote, press a button once for the
first letter, twice for the second letter, and three times for the
third letter -- then press the Track Up or Next Track key to send the
letter.
To send the letter 'A', press the 2 key once and then
press the Track Up key. To send the letter 'B', press the 2 key twice
and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There
is a reported bug in the security code handling of some Kenwood
stereos. In models with thie bug, the security code is stored
incorrectly. The workaround is to enter the wrong security code.
In
models with this bug, you have to decrement the third character of the
security code by one. If your security code was 1111, you would enter
your security code as 1101. If your security code was 9999, you would
enter 9989.
