Acer Veriton M661  PC Desktop Logo
Anonymous Posted on May 22, 2012
I am trying to install a Q9550 to My Acer EQ35M ,SMbios ver2.5 system bios version ROI-B2, i am curently sucessfully using a E4700 core 2 duo with no problems but want to upgrade to quad core. the Q
My system runs without issue with the supplied E4700 2.6 GHZ core two quad.cpu ,however i would like to upgrade to the Q9550 2.83 quad core 1333 fsb 12Mb L2. When i install it , the system starts,beeps then goes no further.
Anonymous
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on May 22, 2012
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
Helped
8002
Points
36
In most cases like this it means that the motherboard just can't handle the new processor. There should be a beep chart in your motherboard documentation that will tell you what the beeps mean. For example, one set will mean that the RAM is not there whereas another might say I don't think I have a processor. Often upgrading the processor requires extensive reflashing of your BIOS to support the processor IF the motherboard can even do it. Always read very carefully to see what processors your motherboard will support. Depending on your RAM, you might even have issues with the RAM. Sorry for all the bad news.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 3 Answers
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
781
Points
9
Have you visited the vendors website to check if it's compatible?
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on Oct 07, 2009
SOURCE: Acer Veriton M464 E4700 2.6Mhz cpu upgrade on MCP730 Mobo
Go to www.newegg.com and whatever you want to upgrade click on that item and match it up with your current board (by looking at the specifications and matching them). I suggest to buy a new mobo and all new processors and ram. You can use your old case, hard drive and all that good stuff that is removable.
Anonymous
  • 87 Answers
  • Posted on Oct 24, 2008
SOURCE: Acer Veriton 5600G Front Side Bus settings/jumpers
Hi Gerry,
The understanding of how this works will require some study on your part. This is because you would not have enough basic knowledge to understand any short answers, that someone might give.
Here are some resources for you to read so you will understand this subject.
http://computer.howstuffworks.com/motherboard4.htm
http://www.directron.com/fsbguide.html
http://en.wikipedia.org/wiki/Front_side_bus
I hope you will find the answers you are looking for here.
Good luck.
Anonymous
  • 61 Answers
  • Posted on Nov 10, 2010
SOURCE: i just want to ask if it is possible to upgrade my
sure i think.
Anonymous
  • 1179 Answers
  • Posted on Feb 08, 2011
SOURCE: i have 2 problems: 1. can this type acer run mac
The answer to your first question is yes, your computer is compatible with the MAC OS. However it is very important to continue to ask this question to the MAC Salesperson you deal with when purchasing the software.
The answer to your second question is to do with Heat. Your computer is overheating and is therefore slowing down so it does not fry your CPU. You need to ensure that the Processor Heat sink is making proper contact with the CPU and the fan is connected to the computer main board. Clean the computer of all dust and install as many fans as your computer chassis will allow.
I think this chassis supports up to 80mm fans.
A well cooled computer chassis will work efficiently and effectively.
The Cooler Master Geminii S CPU cooler is a very good CPU cooler for your Processor.
It will reduce the temperature of your Processor by several degrees.
It is very important to get as much, cooler fresh air into your computer chassis as possible. As this will mean that your computer system will run at a far cooler temperature.
damnor01
Anonymous
  • 3153 Answers
  • Posted on Mar 15, 2011
SOURCE: ello. I wanted to know if
The AHCI can be enabled from using the correct driver but you should have enabled it PRIOR to the OS install
Acer did not always do this but often relied on compatibility mode
The speed increase is often not that much.
The BIOS on that board can be updated but you may find that AHCI still does not work as you expect.
Hello sir i have hp narmada tg33mk mother board,it will support i3,i5,i7 processor
you posted a statement of fact not a question.
it will support
not
will it support(a real question)
well NO
and NO PC stated, only mobo.(lost the PC ?)
nor that this PC was mobo bought in India?
YOUR mobo is core2, not core(tm) processor
they are not even the same class nor socket
no
here is the list of core i3 (all are LGA
your mobo is core2. (older )
all are over 1000 pins, LGA1156 (gen 0)
you can not stuff 10 pounds(or kg) of mud in 1 pound sack.
no can do.
1helpful
Video Card
Wow, I think/know you went down the wrong path would you like to try troubleshooting with me?
2helpful
Download driver free
Drivers for Intel products can be downloaded from www.intel.com You will need to know what operating system you are using.
14.April.2014
1helpful
Q9550 With Acer EQ35M MOBO
It is very likely that you simply do not have the right BIOS setup for the new processor. You will likely have to flash all your bios to get the new processor to both be recognized and to be able to recognize components on the motherboard. That is quite a jump in technology and it may be that the motherboard simply will not support the new processor period. In that case, be VERY careful buying your new board and make sure it specifically supports your processor. Sorry I could not be more help!
2helpful
Ello. I wanted to know if there is a BIOS update for the Aspire M1100 because my BIOS dated 23/02/2008 which references are Motherboard SMBios version 2.5 Acer F690GVM Bios: Phoenix Technologies,...
2helpful
2answers
F672cr(m1610)and intel core duo?
The Acer M1610 was available with the following processors: Intel Core 2 Duo, Intel Pentium Dual-Core, Intel Pentium D/4, Intel Celeron D/4 2.0GHz.
Based on this information, It is likely that you can support a Core Duo or a Core 2 Duo, however may be limited to the 2.0GHz models due to clock and multiplier limitations on the BIOS. This may be different if there is BIOS upgrades to support faster processors.
Your best option of the above listed processors will be the Core 2 Duo, however their system specifications report that only the Core 2 with 800MHz or less Front Side Bus are supported.
Also note that the Celeron 430 is a 64bit processor, so it is not likely to work on this system either.
Can i use nvidia 8600 video card for my mother board asus p5pe-vm and processor intel core 2 duo to my motherboard
this are the CPU -s that you're mb can support (core 2 duo)the numbers after "All" are the bios version's you need for the cpu: Core 2 Duo E4300 (1.8GHz,800FSB,L2:2MB,65W,rev.L2) ALL 1201 Core 2 Duo E4400 (2.0GHz,800FSB,L2:2MB,65W,rev.L2) ALL 1202 Core 2 Duo E4500 (2.2GHz,800FSB,L2:2MB,65W,rev.M0) ALL 1406 Core 2 Duo E4600 (2.4GHz,800FSB,L2:2MB,65W,rev.M0) ALL 1406 Core 2 Duo E4700 (2.6GHz,800FSB,L2:2MB,revG0) ALL 1501 Core 2 Duo E6300 (1.86GHz,1066FSB,L2:2MB,rev.B2) ALL 0604 Core 2 Duo E6300 (1.86GHz,1066FSB,L2:2MB,rev.L2) ALL 1201 Core 2 Duo E6320 (1.86GHz,1066FSB,B2:4MB,rev.B2) ALL 1402 Core 2 Duo E6400 (2.13GHz,1066FSB,L2:2MB,rev.B2) ALL 0604 Core 2 Duo E6400 (2.13GHz,1066FSB,L2:2MB,rev.L2) ALL 1201 Core 2 Duo E6420 (2.13GHz,1066FSB,L2:4MB,rev.B2) ALL 1402 Core 2 Duo E6600 (2.40GHz,1066FSB,L2:4MB,rev.B2) ALL 0604 Core 2 Duo E6700 (2.66GHz,1066FSB,L2:4MB,rev.B2) ALL 0604 Core 2 Extreme X6800(2.93GHz,1066FSB,L2:4MB,revB2) ALL 0604 and for the graphic card ...no because you motherboard has the "AGP" interface and the nvidia 8600 has "PCI - express" interface as is described here: http://www.nvidia.com/object/geforce_8600_8500_tech_specs.html
1helpful
Intel Core 2 Quad Q9550 2.83ghz displaying as Pentium III Xeon
This could simply be an issue with you bios. Flash to the latest bios version.
From the site it looks like the Mars has had some bios issues in the past.
Nice setup btw
1helpful
P5ld2-vm problem
go to "bios settings" by pressing "delete" key or F2 at the system start up time .. after going in to bios then search for the options load optimal defaults ....then save it and exit ..
after that restart ...
now have a check if your problem persists then the processor which you have choosed might not support the motherboard specification the frequency of the processor is higher than the specified rate .. check here for the details of the processor which supports your motherboard
Intel Core 2 Duo HH80557PG0332M BX80557E4300 E4300 1.8GHz,800FSB,L2:2MB,65W,rev.L2 1102 2.00G HH80557PG0332M BX80557E4300 E4300 1.8GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0412M BX80557E4400 E4400 2.0GHz,800FSB,L2:2MB,65W,rev.L2 1202 2.00G HH80557PG0412M BX80557E4400 E4400 2.0GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0492M BX80557E4500 E4500 2.2GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0562M BX80557E4600 E4600 2.4GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0642M BX80557E4700 E4700 2.6GHz,800FSB,L2:2MB,revG0 1401 2.00G HH80557PH0362M BX80557E6300 E6300 1.86GHz,1066FSB,L2:2MB,rev.B2 0901 2.00G HH80557PH0362M BX80557E6300 E6300 1.86GHz,1066FSB,L2:2MB,rev.L2 1202 2.00G HH80557PH0364M BX80557E6320 E6320 1.86GHz,1066FSB,B2:4MB,rev.B2 1202 2.00G HH80557PH0462M BX80557E6400 E6400 2.13GHz,1066FSB,L2:2MB,rev.B2 0901 2.00G HH80557PH0462M BX80557E6400 E6400 2.13GHz,1066FSB,L2:2MB,rev.L2 1202 2.00G HH80557PH0464M BX80557E6420 E6420 2.13GHz,1066FSB,L2:4MB,rev.B2 1202 2.00G HH80557PH0564M BX80557E6600 E6600 2.40GHz,1066FSB,L2:4MB,rev.B2 0901 2.00G HH80557PH0674M BX80557E6700 E6700 2.66GHz,1066FSB,L2:4MB,rev.B2
check the website given below for details :
http://www.cpu-upgrade.com/mb-ASUS/P5LD2-VM.html
thank you
rate my solution
2helpful
2answers
Acer boards
this is what your comp can be upgraded to threw these specs i had in my comp book specifacations
hope this helps
Specifications Product
Aspire E560 Language
English Model
Aspire E560 Specifications Specifications
Processor
Intel® Core™ 2 Duo processor up to 2.13GHz with 1066MHz system bus
or Intel® Pentium® D processor up to 3.4 GHz with 800MHz system bus
or Intel® Pentium® 4 processor up to 2.8GHz with 800MHz system bus
Cache
Depending on the CPU
Memory
256MB 400/533/667 DDR2 expandable up to 4GB
BIOS
Flash BIOS
Supported Protocols
PCIX 1.0, PCI 2.2, APM 1.2, VESA/DPMS (VBE/PM V1.1), SMBIOS 2.3,
E-IDE 1.1, ACPI 1.0b, ESCD 1.03, PnP 1.0a, Bootable CD-ROM 1.0,
USB 1.1~USB 2.0, UHCI 1.0, ANSI ATA 3.0, ATAPI
FCC, ETL and NOM certifications v 1.10
System Chipset
ATI RC415 + ATI SB600
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
