Question about Sennheiser 100/500 G2 Series Wireless Combo Kit EW150ENGG2C Microphone
I have a Sennheiser ew 100 G2 wireless mic. I thought the original problem was the red off/on button was missing, but when I opened the bottom of the microphone to replace the part, I noticed the pieces that I assume link up to the button were loose and came off. Is this fixable at my level? Is there a diagram or picture resource I can access of the inside of this microphone?
This isn't a solution. But after I've gotten into my microphone with the same issue using a torx screwdriver I found that I (Electrical Engineer) don't have the proper equipment to fix the issue. Roughly 100 dollars (Flat rate) and a send off to Sennheiser is your best bet.
Posted on Mar 01, 2014
SOURCE: On/off button fell off Sennheiser wireless mic
This is quite common with G2's, and really annoying!
If you are lucky, 50% of the time the red button is pushed inside the mic.
You need to remove the bottom section:
- open the battery compartment
- there should be 3 star-bit screws around the outside (remove)
- pull the bottom of the mic off
If the red button is not inside, they are available as a spare part from Sennheiser dealers.
Be carefull when putting the mic back together, it needs to line up correctly with the internal guides, forcing the base back on could damage the ribbon cable. when the line-up is correct it slides on very easily.
Best of luck.
PTB
Posted on Jul 07, 2009
SOURCE: Sennheiser ew 100 g2 handheld microphone loose coil in capsule?
I had a similar problem with a sure sm 57 that I used on a guitar amp. I don't know if this is the correct fix but it worked for me. I took thin strips of paper to use as spacers and placed them evenly around the coil. I used a hot melt glue gun and placed 3 small drops around the edge of the coil. Remove the spacers and the coil should be secure.
Joey Clay
Posted on Oct 28, 2009
SOURCE: It appears the power on/off
Often the rubber button is pushed into the microphone.
You can easily disasemble the unit.
Just open the batterycase, you will find some small torx screws.
Regards,
Gerard
Posted on Mar 22, 2011
Jan 23, 2014 | Sennheiser Evolution G2 100 Series UHF...
Feb 07, 2018 | Sennheiser Evolution G2 100 Series UHF...
Jul 06, 2011 | Audio Players & Recorders
Mar 22, 2011 | Sennheiser Audio Players & Recorders
Feb 10, 2011 | Sennheiser 100/500 G2 Series Wireless...
Oct 03, 2010 | Sennheiser 100/500 G2 Series Wireless...
Jul 06, 2009 | Sennheiser 100/500 G2 Series Wireless...
Jan 30, 2009 | Sennheiser 100/500 G2 Series Wireless...
Oct 14, 2008 | Sennheiser Evolution 100 G2 (SEN-EW152G2)...
Dec 14, 2007 | Sennheiser SKM100 Wireless Handheld...
