I stick the cable in the computer but the computer does'nt show the mp
SOURCE: firmware issue
go to www.panasonic.com. look for the tab near the top that says downloads or support. enter your model number in the search box. download the firmware. follow the instructions that come with it.
SOURCE: connection
should have at least windows 2000 sp4 or xp sp1 as operating system. plug into usb port on computer while computer is turned on. computer should recognize and install it as mass storage usb device and assign it a drive letter. sometimes xp will recognize it as a panasonic mtp device. this doesn't matter, you can still drag and drop files on it through windows explorer file manager.
Try reseting the unit.
1) Slide the hold
switch to on
2) Turn power on.
3) While unit screen says hold, push:
(mode)(-)(+)(-)(+)(mode)(+)(mode)
This should reset it.
Source: http://www.fixya.com/support/t129568-frozen_displays_wait
SOURCE: someone good with panasonic sv-mp020 please help me!!!what does OVER LIMIT mean?
Try resetting the mp3 player. You can do this by sliding the hold button over and then turning it on. While on it should say hold. Then you push mode (-)(+)(-)(+)Mode(+)Mode(+)
Granted, that will deleted all the songs you have on there so make sure you have them backed up somewhere you can place them back on there.
I hope this helps.
SOURCE: Panasonic SV-MP020 Wait Problem
Make sure the usb jack is all the way in the player. Mine had a couple of mm of metal showing and felt like it was in, the display lit up, said 'wait' and then 'goodbye' :-(. Only later did I realise the jack still could be pushed fully in a bit further, and then *bingo*, a working mp3 player
