Question about Nintendo 3ds Handheld Game Console- Cosmo Black for DS
3ds error code 52010
How to get to stop it from going to block my wi-fi connection.
5 Related Answers
Sparky707
Sparky707
  • 19 Answers
SOURCE: I have a nintendo 3DS and I want to know how to
OK, first of all you'll need an internet connection yourself.
Click the options menu and go to "other" (The orange one). Scroll along until you find "system update". Connect to wi-fi and update the system, DO NOT stop it once it's begun as it could harm your data.
Once the system is up to date, click on the blue globe in the top left of the main menu, et voila.
All you really need to do is update the system, so once you've done that all you need is to be near your wi-fi connection and you'll be fine.
Hope this helps, even if it is a little long winded =P
(NOTE: It won't be able to play videos like on youtube for some reason or other... nothing you can do but wait and see if Nintendo will update browsing capacity...)
Posted on Jul 22, 2011
Anonymous
SOURCE: my ds cant find my wi-fi adapter
dont worry ppl i fixed it, i found out that my internet connction that was going through the W-Fi adatper, wasnt accepting echo requests. but it works now.
Posted on Jun 13, 2009
shaun taylor
  • 1527 Answers
SOURCE: can`t get wi-fi connection.
hello you might need to pair them first if you've got router there should a pair button on the side of the router once these have bin paired the you might have insert you wep key .good luck
shaun
Posted on Aug 02, 2009
Anonymous
  • 1234 Answers
SOURCE: trying to connect to internet
Error Code: 52230 There appears to be an issue with your wireless router's firewall.
  1. It is possible that your Internet Service Provider (ISP) is not compatible with the Wii console. For instance, if you need to login with a user name and password when you try to go online for the first time after restrarting your PC, your ISP is likely not compatible. Please contact your service provider for more information.
  2. If this error occurs regularly, while you are playing at home, it is likely a connection problem related to your firewall settings. For more information on firewalls, click here.
  3. Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
Posted on Aug 25, 2010
angelo_mlc
Angelito Rabago
  • 1035 Answers
SOURCE: i can't connect my Dsi
Hi. This is a common issue for this console. Try resetting the router, or change the security code / security type.
Posted on Sep 13, 2010
HOW CAN I CONNECT WI FI TO MY NINTENDO 3 DS
the 3ds would have to have the ability to go onto your wireless service. find out if the 3ds has wifi if so you will need to connect to your wifi with your wifi username and password
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Oct 14, 2017 | Nintendo Video Game Consoles & Games
How to connect to nintendo zone
Be sure Wi-fi is enabled on your portable Nintendo device. Then, go to a Nintendo zone location (such as a McDonald's). Your device should connect automatically. If it does not connect, you may need to go into the 'Settings' menu of your device and connect to the Nintendo zone Wi-fi manually. Or you may not be close enough to the Wi-fi signal for your device to connect.
Dec 14, 2015 | Nintendo 3ds Handheld Game Console- Cosmo...
How can i connect my computer to my nintendo?
https://www.nintendo.co.uk/Support/Nintendo-3DS-2DS/Connecting-to-the-Internet/Connecting-using-a-Nintendo-Wi-Fi-USB-Connector-/Connecting-using-a-Nintendo-Wi-Fi-USB-Connector--243609.html
Mar 04, 2015 | Nintendo 3DS XL - Blue/Black
Support nintendo
As of May 20, 2014, certain online functionality offered through Nintendo Wi-Fiicon1.png Connection is no longer accessible. The discontinued services include online play, matchmaking, and leaderboards for many Wii, Nintendo DS and Nintendo DSi games.
Aug 04, 2014 | Nintendo 3DS XL - Blue/Black
I have a nintendo 3DS and I want to know how to use the internet on it. I have the internet wi-fi connections set but when I tap the internet logo on the touch screen on the 3DS a message appears and says...
Jul 22, 2011 | Nintendo 3ds Handheld Game Console- Cosmo...
Won't connect to Wirelss hot spots outside of home. Wi fi at home works but anywhere else I just get a Error code 003-3201 pops up.
Is the Wifi strong enough to go outside with it? Do you change the WiFi spot outside of your home? For example, if you are at a gas station, do you connect with your home network? This doesn't work.
May 26, 2011 | Nintendo 3ds Handheld Game Console- Cosmo...
Error code 051110-1 How and where do you enter
Go onto the Ds game that your going to play wi fi
go to multiplayer
then Wi-fi
then go into settings and it should come up with 3 boxes of connections , click on and go from there :)
Mar 18, 2011 | Nintendo DS Lite Console
Error code 51332 stopping connection to wi-fi how do i solve this
The best troubleshooting for this issue I've found so far is on this web page.
http://www.nintendo.com/consumer/systems/wii/en_na/onlineWirelessRouterTroubleshooting.jsp
Aug 02, 2008 | Computers & Internet
Nintendo 3ds Handheld Game Console- Cosmo Black for DS Logo
473 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Anon
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
