SOURCE: Bought a Homelite 14" electric chainsaw. After
I am not sure if you have figured out how to put the chain back on your saw or not, but it doesn't take long.
1. Remove the plastic yellow "T" shaped nut on the right side of the saw (towards the front of the motor housing)
2. Remove the black plastic housing that covers the rear section of the bar and chain
3. Place the chain back onto the bar making sure it is facing the correct direction.
4. Place the chain over the rear sprocket area
5. Turn the +/- yellow plastic knob (towards the back of the saw on the right side) in the - direction until the metal guide inside the plastic casing lines up with the hole in the chainsaw bar
6. Replace the black plastic housing and slightly tighten the yellow "T" shaped nut.
7. Now turn the +/- knob until the chain is tight. Once the chain is tight, turn the "T" nut until it is tight and you are ready to cut again.
SOURCE: chain brake will not release (homelite chainsaw)
The header says you have a Homelite saw and if this correct you can go to Homelite.com and look up parts or other information that you might need for your saw. There is also a contact us area. Good luck
SOURCE: homelite cs3314 chainsaw
Here is a link to get you your parts list. Make sure you have your UT#
http://odref.com/homelite/chainsaw/index.html
