Question about Casio Office Equipment & Supplies
MY CALCULATOR IS STUCK ON TRUE/FALSE - Casio Office Equipment & Supplies
Cate
    New Friend:
You just push Mode and then number 1.
Posted on May 11, 2015
  • Kyla
    Kyla Oct 13, 2015
    Thank you #pray4kyla
sebastien
How do you put true and false on?
Posted on Oct 23, 2014
Anthony Noble
The quicker a molecule moves the colder it is
Posted on Dec 10, 2020
3 Related Answers
k24674
  • 8092 Answers
SOURCE: When I try to use
I wish you had thought it worthwhile to specify the model of your calculator. We cannot possibly know them all. Anyway, if it is a Casio or Casio Clone, the computational mode is set to VERIFY. Change it to the general computational mode COMP. For a Casio, press [MODE] key then [1:COMP].
Posted on Jun 27, 2011
k24674
  • 8092 Answers
SOURCE: i have a fx-83GT PLUS
To get to the general computational mode, press MODE and select 1:COMP.
To change the number display mode to another one, Press SHIFT MODE to enter SetUp. Select NORM or Sci for scientific mode.
Posted on Sep 12, 2011
k24674
  • 8092 Answers
SOURCE: I have a casio fx-83gt
The computational mode of your calculator is set to VERIFY. Change it to the general COMPUTATIONAL mode. Press MODE 1 (COMP).
Posted on Jun 06, 2011
A test did not resolve to true of false
Sorry, there is not enough information to have any idea about the problem.
Mar 09, 2014 | Texas Instruments Voyage 200 Calculator
Tip
Samsung Codes
If u Hav problem with installing games above 500kb on samsung Champ the use this way! my secret!! for more contact me at [email protected]
For Full Setting Phone reset- *2767*3855#Games memory- *#52828378#AVA TEST MENU in that go to MEMORY TEST & just changethe number 1460 to 2460 & 1700 to 2700... this makes the big games to workperfect.... 6) Then go to OTA TEST and change 500 Kb into 5 MB......... I mean500 kb to 5000 add one zero and save thats it.. 7) Then install games &enjoy...... IF, IF, IF, IF,IN UR MOBILE .YOU cannot play any game it says JAVAERROR for this problem at first restart the mobile & just follow the steps5 & 6 ok agian the games work properly 8) thats it very simple...........problem comes read this ok........................... if u do dailyu wil get practice ok then no need to read this again.
on May 01, 2012 | Samsung C3300 Champ Touch Camera Slim...
Fx 9750g11
Please read the manual of the calculator. When you go from a scientific calculator to a graphical one there are some simple functionalities that are dropped. If you have any inequalities to solve use the graphing feature. Your solution set will be shaded.
Oct 22, 2013 | Office Equipment & Supplies
I have a fx-83GT PLUS calculator and i went on fix and true/false went go off my screen.how do you put it back to normal?
Sep 11, 2011 | Casio FX-115ES Scientific Calculator
When I try to use my calculator it comes up with TRUE/FALSE I have an exam tomorrow and need to fix it! Please help
Jun 26, 2011 | Office Equipment & Supplies
I used to check my equations on the touchpad nspire by entering the equation and then the answer and it would tell me true or false. I forgot how to do it. Can you help?
I can help you there :) In the upper-left hand corner of your keyboard, below the touch pad, there should be a button labelled '=' Enter the first part of your equation press '=' then enter the second half. After you have entered the equation hit enter and it will tell you if it is true or false.
Feb 07, 2011 | Texas Instruments TI-Nspire Graphic...
I try to load a trig problem with logs and it says false I need the answer not true or false, Can this be fixed?
Go to Menu-Algebra-Trigonometry and type tExpand()
In the bracket goes your expression. I don't know what type of TI instrument you are using but I am using Ti-nspire CAS and it works really good. I hope I have helped
Sep 06, 2010 | Texas Instruments TI-Nspire Graphic...
Programing using if then statements
HP's RPN calculators have always followed the "do if true" rule. If the test is true, the next step is executed. If false, the next step is skipped. So, in your case, you would simply follow the x>y instruction with the goto instruction. If the test is true, execution will brance to the specified label. If false, execution will continue with the step following the goto.
Apr 02, 2009 | HP 35s Scientific Calculator
Top Casio Office Equipment & Supplies Experts
k24674
Carlo Barzo
Carlo Barzo
paulgbrandon
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
