Installation of Vulcan quasar 40 wall furnace
SOURCE: Vulcan Quasar 40 wall furnace - electronic display problem
Have a gasfitter bypass the clock. The clock is the source of the problem. You will then have a manually operated heater.
Posted on Oct 08, 2009
SOURCE: Noisy pilot light Vulcan Quasar 40
Simply clean out the jet tube with a fine wire, the sound you hear is the gas blowing by the irregular edges, and swirling and not mixing and producing sound waves, (Bit like a flute) So, you need to clean the tube right out, and smooth off the end again, & sorta "Countersink", Flame the end too, at the end.use a very fine needle file, and make it look like new, that will sort your problem out. Then adjust so you have a good gas flow. Also check out it isn't blocked too.
Posted on Apr 30, 2010
Apr 05, 2015 | Vulcan Heating & Cooling
Sep 15, 2014 | Video Cameras
Sep 01, 2011 | Heating & Cooling
Aug 24, 2010 | Heating & Cooling
Apr 30, 2010 | Cozy Enclosed Front Console Heater 20,000...
Oct 05, 2009 | Heating & Cooling
Mar 29, 2009 | Vulcan Heating & Cooling
Jul 23, 2008 | Heating & Cooling
47 people viewed this question
