Question about Vulcan Heating & Cooling
SOURCE: Vulcan CX ducted heating
sounds like the thermocouple (that sensors the heat) may be faulty.
you will need a licensed gas fitter for repairs
Posted on Feb 19, 2008
SOURCE: Noisy pilot light Vulcan Quasar 40
Simply clean out the jet tube with a fine wire, the sound you hear is the gas blowing by the irregular edges, and swirling and not mixing and producing sound waves, (Bit like a flute) So, you need to clean the tube right out, and smooth off the end again, & sorta "Countersink", Flame the end too, at the end.use a very fine needle file, and make it look like new, that will sort your problem out. Then adjust so you have a good gas flow. Also check out it isn't blocked too.
Posted on Apr 30, 2010
Nov 05, 2017 | Vulcan Heating & Cooling
Oct 19, 2013 | Heating & Cooling
May 19, 2012 | Heating & Cooling
Jul 14, 2010 | Heating & Cooling
Jul 04, 2009 | Vulcan GCO2D Gas Single Oven
Jun 13, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Jul 09, 2008 | Vulcan EF3 Deep Fryer
Jul 06, 2008 | Heating & Cooling
Feb 19, 2008 | Heating & Cooling
653 people viewed this question
