Question about Stanley Fatmax Xtreme Retractable Utility Knife
Stanley knife 10-777 can not insert blade holder back into knife
Can not reinsert blade holder into knife body
4 Related Answers
Anonymous
SOURCE: Just purchased a Stanley FatMax 10-778 retractable
1. Make sure the side lock is unlocked.
2. Push the thumb tab all the way to the front of the blade handle.
3. Insert the blade in the opening, you may notice two notches on the top side of the blade.
4. Press the small blade release button as you slide the blade into the knife. You may have to jiggle up and down to get the two notches on the blade fully into the handle.
If properly inserted, the exposed area of the blade should look very close to an equilateral triangle.
make sure both notches of the blade are inside the handle. They notch into the thumb lever.
good luck
Posted on Apr 11, 2010
Testimonial: "Thanks so much!"
nielsonplumb
Paul Nielson
  • 92 Answers
SOURCE: I have a stanley FatMax. How do I insert the blade
On the side there is a big gold wheel, twist counter clockwise and the case should split in half, the blade is held by a magnet, prise the old blade off and replace with new one, then put case back together and tighten gold wheel clockwise
Posted on Mar 07, 2011
wentlanv
Handie Andie
  • 710 Answers
SOURCE: When I inserted blade into
Hi Betsy,
Please go to this webpage and read the rants about this product.
Down towards the bottom are reviews written mostly by contractors and such. Review number 3 addresses your problems exactly. http://www.crunchgear.com/2008/12/05/review-stanley-fatmax-utility-knives/
Good luck
Handie Andie
Posted on May 10, 2011
cjdl52
C Lawrence
SOURCE: Stanley 10-777 utility knife: I need to reinsert
I had the same trouble. The blade holder was out of the knife and would not go back in. I fixed it this way: open the screw knob all the way to the least tension. Slide the two parts open but not all the way- there is a tab on the blade holder that gets in the way if you try to drop it in at the fully open position. With the two halves SLIGHTLY open- slide the blade holder in making sure that the tab is seated in it's slot. Depress the thumb tab and bring it to the most forward position and the two halves should be able to be seated together again.
Posted on Dec 12, 2013
I disassembled the Stanley 10 - 788 utility knife completely how do I put it back together
This utility knife reassemblies similar to the original. The only difference is this model uses two screws and that plastic insert. You will align the two metal halves and bring them together. Use care that the blade does not fall out of its holder and the little black plastic piece stays in place, near the blade. This may take a few tries. after you bring the two halves together you will carefully separate the bottom end (farthest from blade). Separate it just enough to slide the plastic insert into position. Once the three pieces align you will know. With little effort the two metal halves will close together. Install the two set screws and test for proper function. I'm including a Youtube video that shows how to properly change the blade and what it will look like after it is reassembled.
https://www.youtube.com/watch?v=5napTSRSyeQ
Sep 23, 2018 | Cutter Tools
Can't close stanley fatmax
It only goes in one way, try to loosen the screw a little
Jul 30, 2012 | Stanley Fatmax Xtreme Retractable Utility...
I have a stanley fatmax knife but it doesn't have the small yellow button to help insert a new blade. what can I do?
HI!Kindly pull the button on the end of the knife and then after you remove that you can now put the blade of your knife.
Aug 21, 2011 | Stanley Utility Knife
Have a Stanley Fat MAx utility knife and unable to open it to load the blade
there is a little black button on the end where the blade comes out. With the blade in the out position,push in the button and pull out the blade. With button pushed insert new blade or turn the old one around to use the other end.let go of the button and you are ready to go.
Jun 26, 2011 | Stanley Utility Knife
Can't reload utillity knife fat max10-778
Hi Mark,
I have several of them. Are you having trouble getting the handle to open up?
I have found that the blade needs to be all the way in to open it. Also, to get the blade holder to sit right.
If this is not the problem, please reply back. Thanks,
Handie Andie
Jun 21, 2011 | Stanley Hand Tools
Cant put the thing back together after putting in new blade !!!fat max knife
some stanley knifes require stanley blades only, or make sure the clip blade is in is seated in the grove completely.
Dec 23, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Stanley 10-801 utility knife. How do you change the replaceble blade?
On the pivot end of the bladed knife is a black plug that says pull. They actually mean "Push". push it away from the knife body and rotate the handle half it's mounted in, down. The body will rotate in half , revealing the utility blade and more blades in the rear storage.Also note the blade depth adjustment has a locking detent. You have to push it to the right to unlock the utility blade.and push it to the right when retracting to fully retract and lock the utility blade.
Nov 26, 2010 | Stanley Garden
Stanley 10-777 utility knife: I need to reinsert the retractable blade slide back into the knife body. I try but the knife won't close.
Oct 27, 2009 | Stanley Hand Tools
Stanley Fatmax Xtreme Retractable Utility Knife Logo
1,941 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Frank Walton
Level 1 Expert
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
