Question about Samsung RFG297HDRS 29.0 CuFt French Door Refrigerator
I've had the refregerator for 10 months.. All of a sudden water is appearing on the floor next to the refrigerator. Where could it be leaking from?
Posted by Frida Greenberg on
mike cooper
  • 884 Answers
Pull it forward and seei if the drain pan is either overflowing or empty. If it,s empty, check the drain isn't blocked, causing meltwater to leak from inside. If it's overflowing, check the door seals properly and the defrost settings are ok.
Posted on May 22, 2012
Kenmore refrigerator with a bottom freezer leaks water on floor
Hello Wayne,
You already mentioned the reason for the excess water. When the freezer automatically defrosts itself once every 24 hours the melted water drains down through a tube down to a water pan at the bottom of the refrigerator where it sits and supposedly evaporated by the fan back into the atmosphere. However in your case the excessive dust is preventing the evaporation phase to occur by the fan. You need to vacuum as much of the dust as possible and your problem will disappear.
Good Luck
Rich Lilja
May 22, 2017 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Ice build up on floor of freezer. can't figure where it is coming from. There is not a drain on bottom panel. Any suggestiuons? Frigidaire model no AFU2067BWL2
I know that your freezer shows a drain in its floor but there is also a drain behind the rear wall and at the bottom of a tray that collects the water during defrost and is surposed to drain that water that comes during defrost and then drains to a pan below the refrigerator and next to compressor. The solution will be to clean out this drain that is hidden from site behind the rear wall. I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Feb 22, 2013 | Freezers
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Jun 04, 2017 | Samsung RF217ACPN - 20 cu. ft. French Door...
My Siemens KG36U170 fridge (upper) over freezer (lower) continually produces water in the lower section which freezes on the floor inside under the lower container and needs hacking out every couple of...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 22, 2011 | Siemens Freezers
I have a Woods refrigerator that is all fridge, no freezer compartment. Model # RFA17NAC. s/n 07605297JG. It is leaking water on the inside of the fridge and collects on the fridge floor. No manual came...
Hi Linda. We have the identical model of Woods all-fridge and
experienced this problem several times over the course of several
months. Hopefully this is still timely.
The short answer is that the clear flexible-plastic drain tube that runs
from the inside rear of the fridge down to the catch tray (underneath
the cabinet, next to the floor, behind the kick-plate) is sufficiently
plugged (with some kind of gunk, probably from a spill inside the
fridge) to cause a back-up. I suppose the inner diameter of the tube is
maybe 3/16" so it can easily get clogged. Consequently, the water runs
down the inside back of the fridge & eventually ends up in the
depressions below the crispers. In our case, after those depressions
filled (and I hadn\'t noticed), the water would run out onto the floor.
Initially, I used a fine wire to poke some of the gunk out of the tube
but I didn\'t get it all out. Just enuff to let some of the water get
thru, but the tube would plug up again. After a few repeats of the
problem, separated by a month or 2 each time, I decided a more "drastic"
tube cleaning was required.
I suppose a good strong compressed air blast might clear the tube
completely, but I didn\'t have that available so I had to use a
semi-flexible wire & sorta gunk out the tube. It\'s been about 1.5
yrs. since that more thorough tube cleaning & the problem hasn\'t
come back, so I think the tube got plugged from a spill in the fridge
(which thankfully hasn\'t re-occurred... yet).
BTW, I don\'t have the manual either, but the lower part of the tubing is
accessible from behind the fridge. I didn\'t pull it completely out
(which might have disconnected it from its fitting), I simply reamed it
out while it was in-place.
Hope this has been of some help to you.
Norm.
Aug 26, 2010 | Woods Upright Freezer MU07W
My walk-in freezer is developing stilagtights (ice castles) on the floor and cieling in front of the evaporator coil.MY drain pan is not plugged when I pour water down it.
You should check for air leaks around the door gasket or any other openings in the compartment such as where pipes or wiring is going through the wall. It sounds like a moisture problem from moisture being drawn into the compartment pass door gaskets or access holes.
Mar 07, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Samsung RFG297HDRS 29.0 CuFt French Door Refrigerator Logo
319 people viewed this question
Top Samsung Freezers Experts
John Tripp
John Tripp
Tad
Level 1 Expert
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
