SOURCE: Kenmore 80 series keeps shutting off. new motor and lint line cle
take off the vent line from the back of the dryer,if it runs fine your vent line is blocked or the outside vent where the flapper opens might have a cage on it to keep animals out of the line,it keeps the animals out but it's a lint trap.if you have a long run use a leaf blower and blow out the vent line,if that's ok check the t-stats on the heater box,
Testimonial: "You were right the new motor was bad."
SOURCE: Kenmore 80 series dryer
check to make sure you have 220 volts to dryer. if so check element for continuity make sure power is off
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
SOURCE: kenmore 90 series dryer, motor wont start, loud
when you push start button there is a humming noise and dryer won't start i release the button and noise stops. there is a burning smell. I cleaned the lint from under the dryer and around. I checked the belt and manually rotated the drum no binding. is it the motor or start switch? or what?
Jan Jones
Email: [email protected]
ph: 619-429-5996
