Brother CS6000i Computerized Sewing Machine Logo
Tara Marie Posted on May 21, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I set the machine to get the exact same decorative stitch on both sides?s
  • do you have a manual?
  • Tara Marie May 22, 2012
    I do have a manual, but it does not address my question. When I started to sew with the decorative stitch that I selected the result was exactly what I wanted. (The same on both sides.) However, when I took a break, then went to finish my project, It would only show the stitch on one side. I could not get it to do what it did before. I have tried all the obvious adjustments such as tension, and needle replacement. Please help! I already called the brother helpline and I got someone who didn't know anything about the sewing machine.
Debbi's Sewing Machine Repair
Level 3:
  • Brother Master 7,365 Answers
  • Posted on May 23, 2012
Brother Master
Level 3:
Answers
7365
Questions
Helped
1744172
Points
19451
Did you try turning the machine off & on again to see if it would reset itself
1 Related Answer
Anonymous
  • Posted on Mar 10, 2012
SOURCE: I just got a Brother
I also have this problem, I am very confused and the advice given above is not applicable to the problem. I have rethreaded and changed the tension and all I get is the front of the stitch on the reverse of the fabric. Help
1helpful
I am having troubles with the decorative stitches bought used
Difficult to diagnose. Try a brand new needle that is compatible with the thread and fabric.
All About Needles
If the machine is mechanical, it may need cleaning and oiling if the decorative stitch mechanism is sticking.
I can't get the decorative stitches to work.
if you have the settings correct for the decorative stitches, the there could be something wrong with the gears or cams that make sure decorative stitches and the machine would need to be checked
My decorative stitches are not sewing. The machine sews straight okay but the thread does not catch with the decorative stitches.
there could be a problem with the gear for the decorative stitches, the machine may need to be checked to see if there is a gear or gears damaged or broken
2answers
I have a Janome Newhome 672. Cleaned and oiled it, works great. But, the decorative stitches will not form correctly. The reverse is not engaging. How can I fix this. Also, the button hole knob h
In most cases Laurie, with decorative stitches selected some machines can't sew in reverse. Your stitch length is too long or too short to make the decorative stitches sew correctly. So many things could be wrong. I'd need more info to get you going again.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Only half a stitch
Most likely, your hook timing needs to be adjusted. I'm afraid that this requires a technician, HOWEVER any sewing machine technician can adjust the timing, it's not machine specific.
Dec 31, 2013 • Singer 7422
1helpful
Singer curvy
there could be something wrong with the cam that does the decorative stitches, you may want to have the machine checked..
3answers
All my decorative stitches are comming out straight
it sounds like something has happened to the cam gears that
do the decorative stitches, which means the sewing machine needs
to be checked..
but before you have the machine checked,, make sure all the
dial that are used for decorative stitches are at the right setting
one missed setting can cause a lot of problems
Blanket stitch for the 930 bernina
The Bernina 930 Record does not have a blanket stitch. It has a few decorative stitches that are similar, but not exact.
Kenmore 19365 decorative stitch will not stitch
You have to key in the number for the stitch on the stitch panel
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
